Im trying to run make_toolkit.ipl but i am getting the following errorfiles: [delete] Deleting: C:\iw-home\local\config\lib\content_center\customer_out\customer.tk.war [war] Building war: C:\iw-home\local\config\lib\content_center\customer_out\customer.tk.warBUILD FAILEDC:\iw-home\local\config\lib\content_center\reference\build.xml:116: Execute failed: java.io.IOException: CreateProcess: C:\iw-home\iw-perl\bin\iwperl C:\iw-home/install/clean_tk_war.ipl ../customer_out/customer.tk.war error=193
Check if "C:\iw-home\iw-perl\bin" Directory contains stray "iwperl" File (No extension, zero length) in addition tothe correct "iwperl.exe". If it does - delete it
I think we are getting really good at spotting this issue.
