Hi all,
I am running TeamSite 6.7.2 (UNIX) and using the OOTB ECM Connector to integrate with MediaBin 4.6.2. I upgraded from 4.6.1, and now I am not able to get the integration to work from within TeamSite. I have validated that web services are up and running as expected. When I try to do just a basic import from MedaiBin, I get the following error below. It looks like an authorization issue, but I don't think it is. The integration worked fine before I did the upgrade. Everything else (including user access, permissions, etc...) is working great when I access the MediaBin web client. Does anyone know the ECM Connector needs to be upgraded? I can't find any help on documentation on this.
Thanks
Root cause:
AxisFault
faultCode: {
http://xml.apache.org/axis/}HTTP faultSubcode:
faultString: (401)Unauthorized
faultActor:
faultNode:
faultDetail:
{}:return code: 401
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "
http://www.w3.org/TR/html4/strict.dtd"> <HTML><HEAD><TITLE>You are not authorized to view this page</TITLE>
<META HTTP-EQUIV="Content-Type" Content="text/html; charset=Windows-1252">
<STYLE type="text/css">
BODY { font: 8pt/12pt verdana }
H1 { font: 13pt/15pt verdana }
H2 { font: 8pt/12pt verdana }
A:link { color: red }
A:visited { color: maroon }
</STYLE>
</HEAD><BODY><TABLE width=500 border=0 cellspacing=10><TR><TD>
<h1>You are not authorized to view this page</h1>
You do not have permission to view this directory or page using the credentials that you supplied because your Web browser is sending a WWW-Authenticate header field that the Web server is not configured to accept.
<hr>
<p>Please try the following:</p>
<ul>
<li>Contact the Web site administrator if you believe you should be able to view this directory or page.</li>
<li>Click the <a href="javascript:location.reload()">Refresh</a> button to try again with different credentials.</li>
</ul>
<h2>HTTP Error 401.2 - Unauthorized: Access is denied due to server configuration.<br>Internet Information Services (IIS)</h2>
<hr>
<p>Technical Information (for support personnel)</p>
<ul>
<li>Go to <a href="
http://go.microsoft.com/fwlink/?linkid=8180">Microsoft Product Support Services</a> and perform a title search for the words <b>HTTP</b> and <b>401</b>.</li>
<li>Open <b>IIS Help</b>, which is accessible in IIS Manager (inetmgr),
and search for topics titled <b>About Security</b>, <b>Authentication</b>, and <b>About Custom Error Messages</b>.</li>
</ul>
</TD></TR></TABLE></BODY></HTML>
