Hi All,We are facing problem in a component that is used as the multiple tabs, in which presently we can select more then 1 tab at a time as selected, but we need to put the restriction of the selection of the tab, to select one tab as "yes" at a time.We are allowing user to select the "Yes" or "No" through Apperance XML by the radio button, and using Group replicants for tabs.Dummy Code is attached for the reference.Thanks in advance for help,Vids
