I have a utility which creates file in teamsite using createSimpleFile method of CSSDK API through java . I have created a file , but because of some problem delete that file from teamsite. Now when I again run my utility , it is throwing exception that you can not perform any operation on Hole type of file. I can not modify my utility to add any update code, it contains only code to create a new file. How can I delete file and its hole from Teamsite so that it allow me to create a new file with the same name using createSimpleFile method. Any help regarding this ? Thanks in Advance Abha
I have tried to delete the file from UI but the problem stil persists . The file is in workarea
