Is it possible to integrate AppWorks with Identity management system which will use OpenID connect protocol to send the tokens instead of SAML2.0 tokens? If yes, please suggest possible options available.
Testing
I am trying to configure using Okta
On Okta side
on OTDS side
any other steps to be followed to completed the configuration? whether all the values above are correct?
