Hi All,I need to create a DCT in which there should be one container with "replicant=true" and in a container there will be a radio button field, with the options of "Yes" and "No".DCT should work in a way, if in a container we select a radio button option as "Yes" then for other replicants the selected option should automatically becomes "No".Is there any way to get this, kindly suggest.Thanks in advance for help,Vids
You are correct, I am trying to work with DCT.
