I can't find any documentation about this. Someone alredy try this?
Thanks!
If there are Accepted Answers, those will be shown by default. You can switch to 'All Replies' by selecting the tab below.
Hi RobsonGrangeiro, Did you get the re-solution on this?
Hello Ram_Kishan_Maitry Until now without a solution. Could you know something about? Thanks!
There is an article here that was used to build composer projects using maven that may help you. https://github.com/abykoshy/dctm-docapp
