while uploading document made in ms-power point-2003 ,following error occurs.But we easily upload doc made in ms power-point 2007 even doc saved in word-2003 gets uploaded easily.The below error occurs only when we try to upload doc saved in ms-power point-2003.Error:1.ppt could not be added: MSO Decoder: Error trying to extract PPT slide metadata.Exception in Primitive {F02AA9EB}! Reason = Unspecified error, Message = CLSIDFromProgID() failedERROR: Job {E3227826-20A9-44D4-BFBA-3A355BDE6A6A} Returned error by primitive MS Office Decoder from ForwardSetup(); RC = The operation failed. Check the log output for details thanks.
Few things may help to identify the issue
1. What is the version of MS Office on MB Server ?
2. Did you try to open the PPT on your local machine using MS Office 07 (PP-07)
3. Did you use any task/custom task to upload the ppt ?
Try to open the PPT on your local machine using MS Office 07 (PP-07) , Save and Upload to MB server
-Vin
Thanks for reply.1. There is no MS-office on the Mediabin server.2. I Am not able to upload the ppt saved in 2000-03 version, we can upload & download the MS-Office ppt saved in 2007.3.No,i am not using any task/custom task to upload the ppt.The problem is, client does not want to save its all ppt From 2000-03 version to 2007 version.Please check the attachment for the error screen snap.Thanks.
I will try to replicate the error on my Dev Server and
get back to you with in few days
sorry for the delay.1) OS on the server is window 2000 sp42)sql server 2000If you got any solution,please tell me its urgent.Thanks for reply.
It’s holiday .. ten days to get back little details means …. the issues is not critical ‘will back on first week of jan , 2010 … ‘am away from office, books and . ….(office shutdown )
