Problem with IManExt2.IManMoveContentsCmd
GrahamShaw
Hi
Does anyone have a working code example implementing IManExt2.IManMoveContentsCmd with one and or more documents? I just keep getting a eror:-
iManExt2: IManMoveContents command failed.
iManExt2
The parameter is incorrect.
Would help if it said which param ;o)
G
GrahamShaw
Just for info, the way I got this working was to create a custom Icommand that inherited from the IManMoveContentsCommand and added that as a new custom Icommand menu option, all the implemented properties just called the underlying command's properties / methods except Update which looped through the ContextItems colletion and added the names, type, value (where available) and if an array the count to a string that was set on the clipboard, I then pasted that into Notepad to see exactly what was included for that particular command.
I did the same for any other commands I couldn't get working.
G
