iwextattr problem after opendeploy
MoReese
After OpenDeploy deploys file from one teamsite branch to another, it executes set_attributes.ipl. My set_attributes.ipl is a modification of the perl script interwoven has been distributing. When the script executes, it sometimes doesn't set the first 1 to 4 attributes(different per deployment). When I check my log file, it is correctly calling the iwextattr cmd for those attributes, and is returning no error. If I copy the cmd from the log, and run it at a later time, it works. So, I put a sleep(5) at the begining of the script. I ran a few tests with this in the script, and it set all attributes correctly.
Why should sleeping for 5 seconds work? Has anyone else seen this problem? Is there a better solution?
Migrateduser
Which version of TeamSite and OpenDeploy are you using? What is the platform?
Which DNR trigger point are you using? Perhaps there's a latency issue between the time the file arrives and the iwextattr command gets called.
Todd Scallan
Group Product Manager
Interwoven
t: 408-530-7167
e:
tscallan@interwoven.com
MoReese
I'm using Teamsite Version: 5.5.2.1 , and opendeploy Version: 5.5.1. Both are running on solaris.
Here is the DNR config: (path's are omitted)
<deployNRun>
<dnrDeployment location="target"
when="after"
state="always">
<script cmd="set_attributes.ipl"
async="no"
where=""
</dnrDeployment>
</deployNRun>
I though that there might be a latency issues, but I would think many other people would be seeing this, if this was the issue.
