Hi,I am using XSLPT for DCR.Tinymce is loaded properly in the DCR but when I save the DCR the Text field is showing blank.Please can anyone put some light on this issue
Thanks to all.To answer your question we are using "xml" style in our templating.cfg We have 7 DCTs,all were using VFE External editor earlier now we have to changed to tinymce. For other five tinymce is working fine but for two it was not working fine.If I save the text and reopen DCR, the text got lost and during preview also it is not there.
I have TS 6.7.1 SP 1. I can vouch that this problem still exists in this version. Our workaround was the put a required field at the end of the form.
Has anyone tried adding code to an onsave event to focus on a different item (than the TinyMCE item)? I'm asking more out of curiosity than anything else, especially given that I'm pretty sure this is resolved. I'm skeptical about having the required field because it would only have an impact the first time a form is created and not on subsequent edit, unless you erased the value of the field each time the form was opened, which is moving into kludge territory.
Hi Ghoti,Please find the attached datacapture file along with this message.Take a look and see what the problem is?If we remove the tinymce configuration,It is working fine.
Hi,I found the problem now..Please tell me that do we required to do any branch level configuration for tinymce.Because when I removed the second container,it worked but I need with container.
You're saying you changed it from main/step/text to just main/text or step/text - and that "fixed" the problem?That sounds very strange - if you can easily reproduce it I'd suggest opening a case with Support.
