DataDeploy Problem with TeamSite 6.5 SP3
Lijesh
Hello
We are using datadeploy for one of our sites. The teamsite being used is 6.5 SP3. DD is not a regular deployment which is done and its kind of a blue moon deployment that is done by the users. So now when the user has tried to do a deployment nothing is being inserted into the DB and we are getting such an error in the logs.
DBD: [Mon Jul 25 07:34:45 CDT 2011] Begin executing CLIO_PAGES
DBD: Area VPath:/iwmnt/default/main/manual_content/cml/clio/STAGING
DBD: Setting up consumer TDbAgent
DBD: >>> Loading drivers <<<
DBD: Loading com.informix.jdbc.IfxDriver
DBD: Loading oracle.jdbc.driver.OracleDriver
DBD: Loading com.sybase.jdbc2.jdbc.SybDriver
DBD: Loading COM.ibm.db2.jdbc.app.DB2Driver
DBD: ERROR:ERROR: Loading drivers : COM.ibm.db2.jdbc.app.DB2Driver
DBD:
DBD: *******************************************************
DBD: SQLException occured in JdbcCheckup:LoadDrivers()
DBD: Exception Message: [IBM][JDBC Driver] CLI0647E Error allocating DB2 environment handle, rc=-1.
DBD: Vendor Error Code: 0
DBD: SQL state: null
DBD:
DBD: *******STACK TRACE*************
DBD: ERROR:
java.sql.SQLException: [IBM][JDBC Driver] CLI0647E Error allocating DB2 environment handle, rc=-1.
at COM.ibm.db2.jdbc.app.DB2Driver.(Unknown Source)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:494)
at java.lang.Class.newInstance0(Class.java:350)
at java.lang.Class.newInstance(Class.java:303)
at com.interwoven.dd100.dd.JdbcCheckup.registerDriverWithDriverManager(JdbcCheckup.java:170)
at com.interwoven.dd100.dd.JdbcCheckup.LoadDrivers(JdbcCheckup.java:268)
at com.interwoven.dd100.dd.TDbAgent.(TDbAgent.java:264)
at com.interwoven.dd100.dd.TConsumerManager.SetupConsumer(TConsumerManager.java:602)
at com.interwoven.dd100.dd.TConsumerManager.SetupConsumersForOneDeployment(TConsumerManager.java:192)
at com.interwoven.dd100.dd.TConsumerManager.SetupConsumers(TConsumerManager.java:133)
at com.interwoven.dd100.dd.TAgentClient.Go(TAgentClient.java:105)
at com.interwoven.dd100.dd.IWDataDeploy.Go(IWDataDeploy.java:582)
at com.interwoven.dd100.dd.TDASThread.ProcessItem(TDASThread.java:203)
at com.interwoven.dd100.dd.TDASThread.run(TDASThread.java:128)
DBD: ERROR:
Could somebody please help me out with this issue as its really a showstopper now
nipper
Not much anyone can say, 6.5 is EOL, so you will have trouble with support.
Most likely someone replaced the JDBC driver you were using with a new one. That one may not be supported.
Find out if that happened and what JDBC driver you have. You *may* be able to get it to work with 6.5 or you may need to upgrade.
ACheethayil
It is a JDBC driver issue.
