Problem in Call back method for Dynamic DataSource Call
abhi_bakshi
I'm trying to call a Datasource from my datacapture.cfg (DCT)file dynamically.
I have written a method "init" which invokes the datasource "EquipmentAttachmentDatasource". I'm facing a problem as the callback method is not getting executed in FireFox. However in IE it executes properly
in FireFox it gives the following error
Sarissa.getDomDocument is not a function
var xmlDoc = Sarissa.getDomDocument();
The Code snippet is as follows --
IWEventRegistry.addFormHandler("onFormInit", init);
function init(){
var siteValue = "en_US";
var dataSourceObj = new IWDatasource();
var dsParams = new IWMap();
dsParams.put("productType", "equipment");
dsParams.put("siteName", siteValue);
var returnParams = new IWMap();
returnParams.put("selectItemVpath","/label_root_container/label_container/label_name");
dataSourceObj.executeDatasource("setDatasourceValueCallback", "EquipmentAttachmentDatasource", dsParams, returnParams);
return;
function setDatasourceValueCallback(resultObj, ctxParams)
alert("This is inside Callback");
return;
EquipmentAttachmentDatasource is a MapDatasource which returns Map.
I'm using fireFox 3.6.18, IE 8, Team site 7.1 installed in Windows 2008
Matias
I'm having the same issue. I opened a thread here:
http://devnet.interwoven.com/forums_vb/showthread.php?t=35852&forumid=11
and they had some good ideas. I havent tried the solution yet but it may give you a clue.
abhi_bakshi
Thanks a lot it worked for me.
