My requirement is to dynamically generate a DCT using XMLs that will be aggregated in the server using xincludes. I plan to use datasource feature in inline for which I started with a simple code to first render an item but I am unable to figure out why it does not work.
Java code:
import java.util.Map;
import com.interwoven.datasource.*;
public class DatasourceTest implements SimpleDataSource{
public String execute(String sessionId, String context, Map param){
return("<substitution><item name='testItem' pathid='@testPath'><label>From Datasource</label><textarea /></item></substitution>");
Entry in DataSourceConfig.xml -
<datasource>
<name>TestDS</name>
<classname>DatasourceTest</classname>
<param name="servername">SDW486</param>
</datasource>
Entry in DCT-
<tab name="Additional attributes">
<item name="Users" pathid="@Users">
<label>Author</label>
<description>Select a user who is a TeamSite author</description>
<textarea required="t"/>
</item>
<inline command="Datasource:executeComponent:TestDS:Role=author"/>
<item name="crm_ref" pathid="crm_ref" required="f">
<label>CRM lead ID</label>
<text/>
</item>
Error in logs -
com.interwoven.ui.datacapture.external.InvalidDCTException: com.interwoven.ui.datacapture.external.InvalidDCTException: Invalid Element: option cannot appear at this level.
Appreciate if anybody can throw some light on what possible could be the issue.
