We are facing issues in preveiwing the .page files:- If anybody has got idea to fix it, please help.
below is the error in server.log.
014-12-05 03:35:16,432 INFO [STDOUT] log4j: setFile ended
2014-12-05 03:35:16,432 INFO [STDOUT] log4j: Adding appender named [WCMWEB_WFM] to category [com.interwoven.ui.modeler].
2014-12-05 03:35:16,435 INFO [org.apache.catalina.core.ContainerBase.[jboss.web].[localhost].[/iw-wfm]] Initializing Spring root WebApplicationContext
2014-12-05 03:35:16,576 INFO [org.jboss.deployment.EARDeployer] Started J2EE application: file:/D:/Interwoven/ApplicationContainer/server/default/deploy/iw-wcmweb.ear/
2014-12-05 03:35:16,576 ERROR [org.jboss.deployment.scanner.URLDeploymentScanner] Incomplete Deployment listing:
--- Incompletely deployed packages ---
- jboss.deployment.DeploymentInfo@9f675d15 { url=file:/D:/Interwoven/ApplicationContainer/server/default/deploy/iw-preview.war/ }
deployer: MBeanProxyExt[jboss.web:service=WebServer]
status: Deployment FAILED reason: URL file:/D:/Interwoven/ApplicationContainer/server/default/deploy/iw-preview.war/ deployment failed
state: FAILED
watch: file:/D:/Interwoven/ApplicationContainer/server/default/deploy/iw-preview.war/WEB-INF/web.xml
altDD: null
lastDeployed: 1417775673844
lastModified: 1409028459832
mbeans:
--- MBeans waiting for other MBeans ---
ObjectName: jboss.web.deployment:war=iw-preview.war,id=-1620615915
State: FAILED
Reason: org.jboss.deployment.DeploymentException: URL file:/D:/Interwoven/ApplicationContainer/server/default/deploy/iw-preview.war/ deployment failed
--- MBEANS THAT ARE THE ROOT CAUSE OF THE PROBLEM ---
State: FAILED
2014-12-05 03:35:16,625 INFO [org.jboss.system.server.Server] JBoss (MX MicroKernel) [4.2.3.GA (build: SVNTag=JBoss_4_2_3_GA date=200807181439)] Started in 4m:28s:93ms
2014-12-05 03:36:10,405 ERROR [STDERR] log4j:ERROR Attempted to append to closed appender named [ADMIN].
2014-12-05 03:36:10,406 ERROR [STDERR] log4j:ERROR Attempted to append to closed appender named [ADMIN].
2014-12-05 03:36:10,445 ERROR [STDERR] log4j:ERROR Attempted to append to closed appender named [ADMIN].
2014-12-05 03:37:02,248 INFO [STDOUT] OpenDeploy server host: USBDTMSITE101, RMI registry port: 9173
2014-12-05 03:44:42,382 INFO [org.apache.catalina.core.ContainerBase.[jboss.web].[localhost].[/iw-admin]] Initializing Spring FrameworkServlet 'ActionServlet'
2014-12-05 03:44:44,836 INFO [org.apache.catalina.core.ContainerBase.[jboss.web].[localhost].[/iw-core]] Initializing Spring FrameworkServlet 'ActionServlet'
2014-12-05 03:44:49,305 INFO [org.apache.catalina.core.ContainerBase.[jboss.web].[localhost].[/iw-dcf]] Initializing Spring FrameworkServlet 'ActionServlet'
2014-12-05 03:47:02,930 INFO [STDOUT] OpenDeploy server host: USBDTMSITE101, RMI registry port: 9173
2014-12-05 03:47:07,590 INFO [STDOUT] OpenDeploy server host: USBDTMSITE101, RMI registry port: 9173
