Hi All,
We are facing issue with Teamsite UI which does not come up after the fresh installation. we are getting below errors:
Teamsite - 7.4.1
Server - Windows 2012 (64 bits)
IIS 6
DB - MSSQL
Logs
core.log:-
2014-12-16 00:15:16,213 [main] ERROR com.interwoven.ui.core.action.StateController () - com.interwoven.wcm.service.iwovregistry.common.ConfigException: IRClient configuration file not found [C:\Interwoven\CommonServicesClient/config/ServiceIdMapping.properties]
2014-12-16 00:15:17,213 [main] WARN com.interwoven.serverutils100.utild.UtildClientConfig () - Could not locate system property "iw.client.config.path", trying old keys...
2014-12-16 00:15:17,213 [main] FATAL com.interwoven.serverutils100.utild.UtildClientConfig () - Could not locate system property "iw.client.config.path".
2014-12-16 00:15:17,213 [main] FATAL com.interwoven.serverutils100.utild.UtildClientConfig () - Could not locate system property "iw_ssl_cert.dir".
server.log:-
2014-12-16 03:13:01,446 ERROR [org.apache.catalina.core.ContainerBase.[jboss.web].[localhost].[/iw-cc]] There was a fatal error reading the configuration files. The servlet cannot start.
com.interwoven.ui.base.config.FatalConfigurationException: Error getting trusted client.
Installer Log:-
2014-12-16 01:05:17,410 ERROR com.interwoven.wcm.jboss.api.JBossServiceUtil - javax.naming.CommunicationException: Could not obtain connection to any of these urls: JETUATWEB01:1099 and discovery failed with error: javax.naming.CommunicationException: Receive timed out [Root exception is java.net.SocketTimeoutException: Receive timed out] [Root exception is javax.naming.CommunicationException: Failed to connect to server JETUATWEB01:1099 [Root exception is javax.naming.ServiceUnavailableException: Failed to connect to server JETUATWEB01:1099 [Root exception is java.net.ConnectException: Connection refused: connect]]]
Please find attached log zip.
Teamsite shows up and running on Windows services panel, while running below command, we are getting this error:
.\iwstat.exe, .\iwstoreadm.exe etc..
ERROR:5000013: Unable to establish connection with server
Kindly let me know if someone encountered such issues earlier or someone can trace it up. Would be great help.
Regards,
Jayson
