THRUST SERVICES & TOOLS
CLOUD EDITIONS
A problem was encountered trying to read the datacapture.cfg file for type product. P
Khateef
It would be great some one help me out with the issue I am facing right now.
When I am trying to open dcr file I got the error "A problem was encountered trying to read the datacapture.cfg file for type product. Please contact your system administrator."
When I looked into show details tabs the below message was shown:
Root cause:
DBI connect('TS_DEV1','dresser_ts',...) failed: [Oracle][ODBC][Ora]ORA-12541: TNS:no listener (SQL-HY000)(DBD: db_login/SQLConnect err=-1) at E:/Interwoven/TeamSite/iw-perl/site/lib/TSGlobalSettings.pm line 109 Can't call method "prepare" on an undefined value at E:\Interwoven\TeamSite\local\bin\global\seqproduct.ipl line 11.
Details...
com.interwoven.ui.datacapture.core.dct.InlineCallout$InlineCalloutException: DBI connect('TS_DEV1','dresser_ts',...) failed: [Oracle][ODBC][Ora]ORA-12541: TNS:no listener
at com.interwoven.ui.datacapture.core.dct.InlineCallout.handleClt(InlineCallout.java:248)
at com.interwoven.ui.datacapture.core.dct.InlineCallout.execute(InlineCallout.java:184)
at com.interwoven.ui.datacapture.external.InlineCalloutProcessor.executeInline(InlineCalloutProcessor.java:203)
at com.interwoven.ui.datacapture.external.InlineCalloutProcessor.evaluateInlineCallouts(InlineCalloutProcessor.java:136)
at com.interwoven.ui.formspub.datacapture.DCRPredicate.buildDCRDocument(DCRPredicate.java:199)
at com.interwoven.ui.formspub.datacapture.EditDCRPredicate.execute(EditDCRPredicate.java:77)
at com.interwoven.ui.formspub.datacapture.AbstractOpenDCRCommand.execute(AbstractOpenDCRCommand.java:111)
at com.interwoven.ui.formspub.datacapture.EditDCRCommand.execute(EditDCRCommand.java:149)
at com.interwoven.ui.base.impl.command.CommandHandler.doExecuteCommand(CommandHandler.java:915)
at com.interwoven.ui.base.impl.command.CommandHandler.tryRunCommandDescriptor(CommandHandler.java:748)
at com.interwoven.ui.base.impl.command.CommandHandler.tryRunCommandID(CommandHandler.java:623)
at com.interwoven.ui.base.impl.command.CommandHandler.runCommand(CommandHandler.java:413)
at com.interwoven.ui.base.impl.command.CommandCallbackContextImpl.callback(CommandCallbackContextImpl.java:45)
at com.interwoven.ui.base.wizard.WizardCommand.execute(WizardCommand.java:116)
at com.interwoven.ui.base.impl.command.CommandHandler.runCommandLoop(CommandHandler.java:228)
at com.interwoven.ui.base.impl.command.CommandServlet.doGet(CommandServlet.java:163)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at com.interwoven.livesite.spring.hibernate.web.filter.OpenSessionsInViewFilter.doFilterInternal(OpenSessionsInViewFilter.java:108)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:75)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:183)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:138)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at com.interwoven.ui.base.impl.auth.AuthenticationFilter.doFilter(AuthenticationFilter.java:203)
at com.interwoven.ui.base.util.SetRequestEncodingFilter.doFilter(SetRequestEncodingFilter.java:106)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:619)
ISCBorisB
One of your Datacapture inline's has problems connecting to Database. That may happen for various reasons,
see here
Khateef
Thanks a lot...
send2viki
Hello - I am also having the same issue while trying to edit DCR. Can you please advise me?
A problem was encountered trying to parse the datacapture.cfg file for type Promotions. Please contact your system administrator.
Root cause:
There must be one and only one element.
Details...
com.interwoven.ui.datacapture.external.InvalidDCTException: There must be one and only one
element.
at com.interwoven.ui.datacapture.external.AbstractDCRDocumentBuilder.getSingletonElement(AbstractDCRDocumentBuilder.java:277)
at com.interwoven.ui.datacapture.external.AbstractDCRDocumentBuilder.buildDocument(AbstractDCRDocumentBuilder.java:157)
at com.interwoven.ui.formspub.datacapture.DCRPredicate.buildDCRDocument(DCRPredicate.java:203)
at com.interwoven.ui.formspub.datacapture.EditDCRPredicate.execute(EditDCRPredicate.java:66)
at com.interwoven.ui.formspub.datacapture.AbstractOpenDCRCommand.execute(AbstractOpenDCRCommand.java:112)
at com.interwoven.ui.formspub.datacapture.EditDCRCommand.execute(EditDCRCommand.java:104)
at com.interwoven.ui.base.impl.command.CommandHandler.tryRunCommandDescriptor(CommandHandler.java:752)
at com.interwoven.ui.base.impl.command.CommandHandler.tryRunCommandID(CommandHandler.java:629)
at com.interwoven.ui.base.impl.command.CommandHandler.runCommand(CommandHandler.java:419)
at com.interwoven.ui.base.wizard.WizardCommand.execute(WizardCommand.java:115)
at com.interwoven.ui.base.impl.command.CommandHandler.tryRunForward(CommandHandler.java:651)
at com.interwoven.ui.base.impl.command.CommandHandler.tryRunCommandID(CommandHandler.java:595)
at com.interwoven.ui.base.impl.command.CommandHandler.runCommandLoop(CommandHandler.java:234)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
at com.interwoven.ui.base.impl.auth.AuthenticationFilter.doFilter(AuthenticationFilter.java:204)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202)
at com.interwoven.ui.base.util.SetRequestEncodingFilter.doFilter(SetRequestEncodingFilter.java:105)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:664)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
at java.lang.Thread.run(Thread.java:595)
Regards,
Vignesh
nipper
You should open a new thread, not piggyback on a previous one.
However in your case, read the error. You XML is malformed.
