PERL_DL_NONLAZY=1 /web/soft/iw-home/TeamSite/iw-perl/bin/perl "-MExtUtils::Command::MM" "-e" "test_harness(0, 'blib/lib', 'blib/arch')" t/*.tt/GD..........Can't load './blib/arch/auto/GD/GD.so' for module GD: ./blib/arch/auto/GD/GD.so: wrong ELF class: ELFCLASS64 at /web/soft/iw-home/TeamSite/iw-perl/lib/DynaLoader.pm line 229.
EXTRALIBS = -L/usr/lib64 -L/usr/lib64 -lXpm -lX11 -ljpeg -lfontconfig -lfreetype -lpng12 -lz -lgdLDLOADLIBS = -L/usr/lib64 -L/usr/lib64 -lXpm -lX11 -ljpeg -lfontconfig -lfreetype -lpng12 -lz -lm -lgdBSLOADLIBS =LD_RUN_PATH = /usr/lib64
EXTRALIBS = -L/usr/lib -L/usr/lib -lXpm -lX11 -ljpeg -lfontconfig -lfreetype -lpng12 -lz -lgdLDLOADLIBS = -L/usr/lib -L/usr/lib -lXpm -lX11 -ljpeg -lfontconfig -lfreetype -lpng12 -lz -lm -lgdBSLOADLIBS =LD_RUN_PATH = /usr/lib
LD_RUN_PATH="/usr/lib" cc -m32 -shared -L/usr/local/lib GD.o -o blib/arch/auto/GD/GD.so -L/usr/lib -L/usr/lib -lXpm -lX11 -ljpeg -lfontconfig -lfreetype -lpng12 -lz -lm -lgd/usr/bin/ld: skipping incompatible /usr/lib64/libXpm.so when searching for -lXpm/usr/bin/ld: cannot find -lXpmcollect2: ld returned 1 exit statusmake: *** [blib/arch/auto/GD/GD.so] Error 1
rm -f blib/arch/auto/GD/GD.soLD_RUN_PATH="/usr/lib" gcc -shared -L/usr/local/lib GD.o -o blib/arch/auto/GD/GD.so -L/usr/lib -L/usr/lib -lXpm -lX11 -ljpeg -lfontconfig -lfreetype -lpng12 -lz -lm -lgd/usr/bin/ld: skipping incompatible /usr/lib/libX11.so when searching for -lX11/usr/bin/ld: skipping incompatible /usr/lib/libX11.so when searching for -lX11/usr/bin/ld: skipping incompatible /usr/lib/libjpeg.so when searching for -ljpeg/usr/bin/ld: skipping incompatible /usr/lib/libjpeg.so when searching for -ljpeg/usr/bin/ld: skipping incompatible /usr/lib/libfreetype.so when searching for -lfreetype/usr/bin/ld: skipping incompatible /usr/lib/libfreetype.so when searching for -lfreetype/usr/bin/ld: skipping incompatible /usr/lib/libpng12.so when searching for -lpng12/usr/bin/ld: skipping incompatible /usr/lib/libpng12.a when searching for -lpng12/usr/bin/ld: skipping incompatible /usr/lib/libpng12.so when searching for -lpng12/usr/bin/ld: skipping incompatible /usr/lib/libpng12.a when searching for -lpng12/usr/bin/ld: skipping incompatible /usr/lib/libz.so when searching for -lz/usr/bin/ld: skipping incompatible /usr/lib/libz.a when searching for -lz/usr/bin/ld: skipping incompatible /usr/lib/libz.so when searching for -lz/usr/bin/ld: skipping incompatible /usr/lib/libz.a when searching for -lz/usr/bin/ld: skipping incompatible /usr/lib/libm.so when searching for -lm/usr/bin/ld: skipping incompatible /usr/lib/libm.a when searching for -lm/usr/bin/ld: skipping incompatible /usr/lib/libm.so when searching for -lm/usr/bin/ld: skipping incompatible /usr/lib/libm.a when searching for -lm/usr/bin/ld: skipping incompatible /usr/lib/libgd.so when searching for -lgd/usr/bin/ld: skipping incompatible /usr/lib/libgd.a when searching for -lgd/usr/bin/ld: skipping incompatible /usr/lib/libgd.so when searching for -lgd/usr/bin/ld: skipping incompatible /usr/lib/libgd.a when searching for -lgd/usr/bin/ld: skipping incompatible /usr/lib/libc.so when searching for -lc/usr/bin/ld: skipping incompatible /usr/lib/libc.a when searching for -lc/usr/bin/ld: skipping incompatible /usr/lib/libc.so when searching for -lc/usr/bin/ld: skipping incompatible /usr/lib/libc.a when searching for -lc/usr/bin/ld: warning: i386 architecture of input file `GD.o' is incompatible with i386:x86-64 output
