I have branch permissions set using CSSDK using add-permssions-entry.
However, how do I set the permssions on the workarea with appropriate access previliges. Couldn't find appropriate CL or iwacccess with appropriate arguments.
Any ideas please.
The assets are unix/DOS assets and you can change them with normal OS commands.
The big issue will be if the WA is resticted, then you would need to add a user to a role on that branch
Couldn't quite follow that Andy. Could you please little bit more elaborate. THank you.
Teamsite is on Windows environment and I donot see any argument which sets the permissions on workarea.
I see set-owner, set-group;
I need set-permissions and I tried add-windows-permissions, ended with error that vpath needs to be a folder.
I don't recall if you can set ACLs on the workarea itself, and I don't have an instance in front of me right now.
If you can do it through the GUI, then try specifing the vpath with a trailing /. like this:
/default/main/mybranch/WORKAREA/shared/.
