I'm developing a web application that uses the BIRT viewer for report presentation.
I don't have any problems in my local test environment.
Today I tried to deploy it to a production server (Apache Tomcat/6.0.16) and everything is working out instead of the reports.
My web application is in server/subdir/myApplication.
I have no rights to edit files located in server/WEB-INF, but I have full rights in server/subdir (and thus server/subdir/myApplication).
This is the web.xml of server/subdir/WEB-INF which is the exact same as the one in server/subdir/myApplication/WEB-INF. I'm not sure if this is ok!?
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE web-app
PUBLIC "-//Sun Microsystems, Inc.//DTD Web Application 2.3//EN"
http://java.sun.com/dtd/web-app_2_3.dtd">
<web-app>
<display-name>Eclipse BIRT Report Viewer</display-name>
<!-- Default locale setting -->
<context-param>
<param-name>BIRT_VIEWER_LOCALE</param-name>
<param-value>en-US</param-value>
</context-param>
<!-- Report resources directory for preview. Default to ${birt home} -->
<context-param>
<param-name>BIRT_VIEWER_WORKING_FOLDER</param-name>
<param-value></param-value>
</context-param>
<!-- The generated document files directory. Default to ${birt home}/documents -->
<context-param>
<param-name>BIRT_VIEWER_DOCUMENT_FOLDER</param-name>
<param-value>${birt.viewer.working.path}/documents</param-value>
</context-param>
<!-- If only access the reprot resources under working folder. Default is false -->
<context-param>
<param-name>WORKING_FOLDER_ACCESS_ONLY</param-name>
<param-value>false</param-value>
</context-param>
<!-- Output image/chart directory. Default to ${birt home}/report/images -->
<context-param>
<param-name>BIRT_VIEWER_IMAGE_DIR</param-name>
<param-value>${birt.viewer.working.path}/report/images</param-value>
</context-param>
<!-- Engine log directory. Default to ${birt home}/logs -->
<context-param>
<param-name>BIRT_VIEWER_LOG_DIR</param-name>
<param-value>${birt.viewer.working.path}/logs</param-value>
</context-param>
<!-- Report engine log level -->
<context-param>
<param-name>BIRT_VIEWER_LOG_LEVEL</param-name>
<param-value>WARNING</param-value>
</context-param>
<!-- Directory to store all birt report script libraries (JARs). Default to ${birt home}/scriptlib -->
<context-param>
<param-name>BIRT_VIEWER_SCRIPTLIB_DIR</param-name>
</context-param>
<!-- Resource location directory. Default to ${birt home} -->
<context-param>
<param-name>BIRT_RESOURCE_PATH</param-name>
</context-param>
<!-- Preview report max rows limited. -->
<context-param>
<param-name>BIRT_VIEWER_MAX_ROWS</param-name>
</context-param>
<!-- Preview report max cube fetch levels limited. (Only support to preview a report design file using preview pattern.)-->
<context-param>
<param-name>BIRT_VIEWER_MAX_CUBE_LEVELS</param-name>
</context-param>
<!-- Memory size(MB) for creating cube. -->
<context-param>
<param-name>BIRT_VIEWER_CUBE_MEMORY_SIZE</param-name>
</context-param>
<!-- If always overwrite generated document file.For designer,defalult to false -->
<context-param>
<param-name>BIRT_OVERWRITE_DOCUMENT</param-name>
</context-param>
<!-- Define BIRT viewer configuration file -->
<context-param>
<param-name>BIRT_VIEWER_CONFIG_FILE</param-name>
<param-value>WEB-INF/viewer.properties</param-value>
</context-param>
<!-- If turn on the function that supports print on the server side. Default to on. -->
<context-param>
<param-name>BIRT_VIEWER_PRINT_SERVERSIDE</param-name>
<param-value>ON</param-value>
</context-param>
<!-- If force optimized HTML output. Default to true -->
<context-param>
<param-name>HTML_ENABLE_AGENTSTYLE_ENGINE</param-name>
<param-value>true</param-value>
</context-param>
<!-- Viewer Filter.Currently, set request character encoding to UTF-8. -->
<filter>
<filter-name>ViewerFilter</filter-name>
<filter-class>org.eclipse.birt.report.filter.ViewerFilter</filter-class>
</filter>
<filter-mapping>
<servlet-name>ViewerServlet</servlet-name>
</filter-mapping>
<filter-mapping>
<servlet-name>EngineServlet</servlet-name>
</filter-mapping>
<!-- Viewer Servlet Context Listener -->
<listener>
<listener-class>org.eclipse.birt.report.listener.ViewerServletContextListener</listener-class>
</listener>
<!-- Viewer HttpSession Listener -->
<listener>
<listener-class>org.eclipse.birt.report.listener.ViewerHttpSessionListener</listener-class>
</listener>
<!-- Viewer Servlet, Support SOAP -->
<servlet>
<servlet-class>org.eclipse.birt.report.servlet.ViewerServlet</servlet-class>
</servlet>
<!-- Engine Serlvet -->
<servlet>
<servlet-class>org.eclipse.birt.report.servlet.BirtEngineServlet</servlet-class>
</servlet>
@generated@
<servlet-mapping>
<url-pattern>/frameset</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>/run</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>/preview</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>/download</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>/parameter</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>/document</url-pattern>
</servlet-mapping>
<servlet-mapping>
<url-pattern>/output</url-pattern>
</servlet-mapping>
<taglib>
<taglib-uri>/birt.tld</taglib-uri>
<taglib-location>/WEB-INF/tlds/birt.tld</taglib-location>
</taglib>
</web-app>
I get this error when trying to view a report:
HTTP Status 404 - /subdir/myApplication/preview
type Status report
message /subdir/myApplication/preview
description The requested resource (/subdir/myApplication/preview) is not available.
I hope somebody can give me help with that issue. Don't hesitate to ask questions on details of the directory contents when you think that the problem might be there.
Thanks for your help!
