BIRT 2.3 output format excel and pdf problem
loume
Hi I had use BIRT 2.3 to design some report, and I find some problem when report output format with excel and pdf.
for example:
If data column value I setting format number : Fixed and use 1000s separator,
but in excel column setting is custom #,##0,### format
so when value small than 1000 will become 0,99 like this.
And if I setting format number : Percent and Decinal places 2,
but in excel column setting is custom ###.##%###
so when value is 0.987654321 will become 98.76%54321
In pdf, if output have more than 2 pages, there have some detail data will show in header column
there have three problem, have anyone can help me??
mwilliams
Hi loume,
Can you post some screenshots so we can get a better idea of what you're seeing? Also, if you can recreate this problem using the sample database and attach it to this thread so I can run the report and see what you're seeing, that may be helpful in solving your problem as well.
