Bonjour,<br />
I have a report which contains a grid on MasterPage.<br />
This grid contains Column values from a data set.<br />
This data set contains 1 row (i have used a filter in order to have just one single data row).<br />
I create a computed column with a bollean value true used to test the visibility property.<br />
I modify the visibility property of one of those data binding on the grid and i put a font color Blue.<br />
Using a View Report as HTML the visibility property works correctly.<br />
Using a View Report as PDF the visibility property does not work.<br />
See file XML Source attached<br />
I am using Eclipse BIRT Designer Version 2.3.0.v20080606 Build <2.3.0.v20080618-0630....is this version the latest?<br />
This version was dowloaded from <a class='bbc_url' href='
http://www.birt-exchange.com'>Business Intelligence Software - Reporting Tools - BIRT Exchange</a> and i have loaded Eclipse all-in-one.<br />
Thanks for your answer.<br />
Luis
