Problem with Margin properties on BIRT2.3.1
Luis
Bonjour,
I am testing the new BIRT version (Eclipse BIRT Designer Version 2.3.1.v20080911 Build <2.3.1.v20080922-1151).
And i have found a regression (this problem does not exists on BIRT 2.2.2) on Master page margin property.
One can not modify the margin selection. If you reduce it the only possible values are 3276700 or 32766,75.
Fortunately, one can modify this property on XML source code.
Bye
Luis
mwilliams
Hi Luis,
I am running BIRT 2.3.1 and didn't have an issue changing the size of the margin in the property editor. Maybe I didn't understand the problem correctly. Can you explain more on what you did that didn't work? Thanks.
