Not Able to launch Flash Charts on Web Portal
Shilpa
I made a report having flash chart and deployed it on web portal using Jetspeed.
While viewing report through web,message is displayed that "Flash Chart report items are not supported in this report format."
I have also added all the plugins available from eclipse to my webreport folder.
Can anybody tell me what should I do to embed Flash objects also in my reports launched through portal?
mwilliams
Hi Shilpa,<br />
Are you using Actuate BIRTs Flash charts? If so, you need to use Actuate BIRT Viewer to have these display correctly. If you are using open source WebViewerExample with you own flash objects, then maybe you should try the output mapping instead of the frameset mapping. Maybe the AJAX stuff in the frameset is interfering. In the devShare, there is a nice <a class='bbc_url' href='
http://www.birt-exchange.com/devshare/deploying-birt-reports/492-birt-viewer-2-3-user-reference/#description'>document</a>
; explaining this mapping and other options.
Shilpa
Thanks Michael for the reply,Yes I am using Actuate Flash maps.
But I am not able to open the link u have specified(may be the page is moved to some other location).
So can u help me in integrating Actuale Viewer to my web portal.
mwilliams
Shilpa,
The link in the above post is fixed now.
mwilliams
Shilpa,<br />
These two documents from the documentation page should help you out with installing Actuate's viewer:<br />
http://www.birt-exchange.com/documentation/Manuals10/java-component-install.pdf'>Installing
an Actuate Java Component</a><br />
http://www.birt-exchange.com/documentation/Manuals10/creating-custom-deployment-kit-apps.pdf'>Customizing
and Integrating an Actuate Deployment Kit</a><br />
Also, the <a class='bbc_url' href='
http://www.birt-exchange.com/wiki/Download_and_Install_the_Actuate_Java_Components/'>getting
started guide</a> in the wiki should help too.
AbhayTech
You can do alternative thing just install flash player plugin download from the net ,because i faced the same problem and it was resolved after installing plugin as well as flash player.
Shilpa
Hi Abhay,
I tried installing flash player from Adobe site ..but still I am not able to view flash components if I am using webviewer example ...
However I didn't get ant plugin seperately.Can u let me know the link from where u downloaded ..
