BIRT Report Engine w/ClearQuest reports - JDBC issue
phran
I downloaded the BIRT runtime and I'm trying to use it to run some ClearQuest BIRT reports, but I'm getting JDBC Errors. The docs for the BIRT runtime state:<br />
Configuring JDBC Drivers<br />
You must configure the engine to include any JDBC drivers that you need.<br />
To do this, copy the driver jar file to the ReportEngineInstall/birt-runtime-version/ReportEngine/plugins/org.eclipse.birt.report.data.oda.jdbc_version/drivers Directory.<br />
I've copied every JAR file that looks like it could be a JDBC driver to this directory, but clearly I haven't gotten the right file or combination of files in that directory yet. Here's the command I'm running and the error message:<br />
C:WorkBIRTbirt-runtime-2_3_1ReportEngine>genReport.bat -f PDF -o C:WorkBIRTreport2.pdf C:WorkBIRTDefectAssignee.rptdesign<br />
C:WorkBIRTbirt-runtime-2_3_1ReportEngine>ECHO off<br />
Jan 25, 2009 11:07:24 PM org.eclipse.birt.data.engine.odaconsumer.Driver doGetDriverManifest<br />
SEVERE: Cannot process data source extension configuration.<br />
java.lang.IllegalArgumentException: com.ibm.rational.clearquest.oda.jdbc.dataSource<br />
at org.eclipse.datatools.connectivity.oda.util.manifest.ManifestExplorer.getExtensionManifest(ManifestExplorer.java:200)<br />
at org.eclipse.birt.data.engine.odaconsumer.Driver.doGetDriverManifest(Driver.java:147)<br />
at org.eclipse.birt.data.engine.odaconsumer.Driver.findDataSourceExtensionConfig(Driver.java:123)<br />
at org.eclipse.birt.data.engine.odaconsumer.Driver.getDriverExtensionConfig(Driver.java:78)<br />
at org.eclipse.birt.data.engine.odaconsumer.Driver.getExtensionConfig(Driver.java:60)<br />
at org.eclipse.birt.data.engine.odaconsumer.Driver.getDriverHelper(Driver.java:93)<br />
at org.eclipse.birt.data.engine.odaconsumer.DriverManager.getDriverHelper(DriverManager.java:97)<br />
at org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.openConnection(ConnectionManager.java:144)<br />
at org.eclipse.birt.data.engine.executor.DataSource.newConnection(DataSource.java:210)<br />
at org.eclipse.birt.data.engine.executor.DataSource.open(DataSource.java:197)<br />
at org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiDataSource(DataSourceRuntime.java:209)<br />
at org.eclipse.birt.data.engine.impl.QueryExecutor.openDataSource(QueryExecutor.java:386)<br />
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:305)<br />
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(PreparedQuery.java:498)<br />
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.produceQueryResults(PreparedDataSourceQuery.java:189)<br />
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:177)<br />
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute(PreparedOdaDSQuery.java:143)<br />
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:479)<br />
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:114)<br />
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:248)<br />
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1736)<br />
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:77)<br />
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)<br />
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:42)<br />
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:45)<br />
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:33)<br />
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:63)<br />
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:90)<br />
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:101)<br />
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:151)<br />
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:72)<br />
at org.eclipse.birt.report.engine.api.ReportRunner.runAndRenderReport(ReportRunner.java:225)<br />
at org.eclipse.birt.report.engine.api.ReportRunner.execute(ReportRunner.java:165)<br />
at org.eclipse.birt.report.engine.api.ReportRunner.main(ReportRunner.java:120)<br />
C:WorkBIRTbirt-runtime-2_3_1ReportEngine><br />
It's not stated anywhere in the docs, but given that the error involves Manifest files, is there a file I need to update to allow the BIRT engine to see the JDBC driver?<br />
Anyone out there seen this?<br />
Thanks in advance....<br />
Fran Kemp<br />
<a href='mailto:' title='E-mail Link' class='bbc_email'>fdkemp@PraxisEng.com</a>
Virgil Dodson
Hi Fran,<br />
Are you using ClearQuest 7.1? If so, there is a ClearQuest ODA driver that provides access to the ClearQuest data. I've started creating a page with instructions for ClearQuest users who want to use the Actuate BIRT products. That page is a work in progress but lists the JAR files that are needed in order to access ClearQuest 7.1 data.<br />
<a class='bbc_url' href='
http://www.birt-exchange.com/wiki/Using_BIRT_and_Actuate_with_IBM_ClearQuest/'>Using
BIRT and Actuate with IBM ClearQuest - BIRT Wiki - BIRT Exchange</a>
LizM
I'm reporting from a RequisitePro repository using BIRT via the Eclipse report builder and experienced similar issues when first setting up the datasource
I needed to install the JDBC driver for the particular database version that the ReqPro repository was using (SQL Server 2005 in this case)
