problem for delpoy EAR to was6.1
TADY6
Hi all,
Anybody faced the error?
Error info:
Cant startup the OSGI framework.
The ear struction :
my.ear
|---birt.jar
|---BirtEngineHome
|---com.tady.MyEngine.jave
|---other jar files
The code call BirtEngine in MyEngine.java.
Following is part info of the MyEngine.java
EngineConfig config = new EngineConfig();
config.setEngineHome = ("BirtEngineHome");
config.setLogConfig(null,Level.FINE);
config.getAppContext.put(EngineContants.APPCONTEXT_CLASSLOADER_KEY, MyEngine.class.getClassLoader());
Platform.startup(config);
I can confirm the problem is the setting of birtengine home incorrect, and How to set the birtengine home for my.ear?
cypherdj
Does your web application contain WEB-INF/platform and its subfolders?<br />
Also in my own web app, I set BirtEngineHome to an empty string.<br />
IPlatformContext platformCtx = new PlatformServletContext(context.getServletContext());
EngineConfig engineConfig = new EngineConfig();
engineConfig.setEngineHome("");
engineConfig.setPlatformContext(platformCtx);
engineConfig.setResourcePath(MyEngine.class.getResource("/").getPath());
Platform.startup(engineConfig);
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY);
IReportEngine reportEngine = factory.createReportEngine(engineConfig);
</pre>
Hope that helps,<br />
Cedric
TADY6
Hi Cedric,<br />
Thanks for your advice! but my.ear package have not included web application, and birt engine is called by ejb, and i packed birt engine with ejb to my.ear package, then provides the service for other applications.<br />
<blockquote class='ipsBlockquote' data-author="cypherdj"><p>Does your web application contain WEB-INF/platform and its subfolders?<br />
</pre>
Cedric</p></blockquote>
