Reg. Two Sql connection for scripteddata source and sql connection termination
jumbogram
I am using BIRT 2.2.0 .
I have created a class that access mysql database and returns some data.
This class I am using for a scripted data source.
Now the problem that I am facing are :
1. For every creation of report , two database connection are made to
the database. I am not able to figure out why ?
2. After the report is rendered , those connection do not terminate and
continue indefinitely and are closed only after I close eclipse. Thus
connections keep on gathering and after sometime databases server
crashes.
I guess their is no error with the class file.
Evern so it is as follows
package BIRT;
import java.sql.Connection;
import java.sql.DriverManager;
import java.sql.ResultSet;
import java.sql.SQLException;
import java.sql.Statement;
import java.util.ArrayList;
import java.util.List;
public class Mysqlclass {
public List<String[]> data() {
Connection con = null;
ArrayList <String[]> result = new ArrayList <String[]>();
try {
Class.forName("com.mysql.jdbc.Driver");
String url = "jdbc:mysql://localhost:3306/DB";
// Get a connection to the database for a
// user named auser with the password
// drowssap, which is password spelled
// backwards.
con = DriverManager.getConnection(url, "root","password");
Statement st = con.createStatement();
ResultSet rs = st.executeQuery("select UserLogin,StatType
from table");
while(rs.next())
String[] result1 = {"",""};
result1[0]= rs.getString("UserLogin");
result1[1]=rs.getString("StatType");
result.add(result1);
} catch (Exception e) {
e.printStackTrace();
System.out.println("Exception: " + e.getMessage());
} finally {
try {
if (con != null)
con.close();
} catch (SQLException e) {
System.out.println("Error with closing the collection");
return result;
Any help is greatly appreciated.
Regards,
Shivam Agarwal
There are no comments yet
