Script Problem
vishalkp
Hello All,
I am facing a problem while using this script.
when i run this report, i get alert for imageid and str, but i am not able to get "elem" and the function exits without showing the alert for "elem"
I am using BIRT 2.3.2 All in One.
alert(imageID);
var str;
str=imageID;
alert(str);
var elem1 = document.getElementById('container').innerHTML;
var elem = document.getElementById(imageID).value;
alert(elem);
elem.style.display = 'none';
alert("Func Exit");
I think I am not able to get this document.getElementById working, or is there some other reason.
when i tried this in Actuate 10 demo edition, its working fine.
Please reply your suggestion.
Thanks in Advance...
With regards,
Vishal KP.
johnw
Try it without the .value, and test for null.
Is this script being executed in a text element, or a chart?
vishalkp
Hello All,
I got the problem solved.
I removed the following statement:
& it is working fine.
And also as per John's comment i also removed .value from the below statement:
Thanks all & John,
With Regards,
Vishal KP.
