Using same column with different WHERE condition
BIRTing
Hi All,
Actually I have to fetch the values from a column 3 times with 3 different where conditions and they have to be displayed as 3 different fields in report.
Is it possible to use 2 queries in an open method??
Or any suggestions for this case??
Sankar Ganesh
mwilliams
Hi Sankar,
Is there a common key between these values that you will be joining them on?
al91206
Can you use the expression builder for each column on the same table to implement if / else statements or a case statement to implement the necessary changes?
I haven't tried that but my associate here is working on just such a report.
BIRTing
Hi Michael,
Thanks!. Actually I am using only one table.. In that there is a column called 'Wonum' i want to fetch count(wonum) in 3 fields with 3 different where condions...
Some one has mentioned , we can use expression builder .. how it can be done .. Can you provide me one example
Sankar Ganesh
mwilliams
Sankar,
So, you have a table, where depending on a field value in it, you want to display 1 of 3 different values from that row from a given dataSet? Is this correct? If so, are they all of the same data type, i.e. integer, string, etc?
BIRTing
Michael,
Thanks a lot for your help!!
They are all of same datatypes only.. because i refer to the same column in database..
And I tried using this Query...
select location,count(wonum) as wocount,wopriority,"
+"(select count(wonum) from workorder where location=w.location and wopriority=w.wopriority "
+" and actstart<=targstartdate) as wocount_response,"
+"(select count(wonum) from workorder where location=w.location "
+" and wopriority=w.wopriority and actfinish<=targcompdate) as wocount_repair from workorder w
Here i am referring count(wonum) 3 times in 3 different where condition..
It fetches some rows... but i am not sure whether its correct or not...
Or is there any better way to do it..
Sankar Ganesh
