Problem with joint dataset(scripteddataset + mysqldataset
doublehawk
I have a scripted dataset with the following values and source:
result|resulttext
0____|unworked
1____|passed
2____|partially passed
3____|failed
4____|blocked
ON OPEN
cnt=0
ON FETCH
var myarr1 = new Array();
myarr1[0] = 0;
myarr1[1] = 1;
myarr1[2] = 2;
myarr1[3] = 3;
myarr1[4] = 4;
var myarr2 = new Array();
myarr2[0] = "unworked";
myarr2[1] = "passed";
myarr2[2] = "partially passed";
myarr2[3] = "failed";
myarr2[4] = "blocked";
var parmcount =myarr1.length;
while(cnt<parmcount)
row["result"] = myarr1[cnt];
row["resulttext"] = myarr2[cnt];
cnt++;
return true;
return true;
And I have a jdbc based datasource that looks for example as follows:
result|count(*)|resulttext
0____|5______|unworked
1____|121____|passed
3____|21_____|failed
SELECT count(*), testresults.result
FROM testcases, testresultsets, testresults
WHERE testresultsets.relatedws = ?
AND testresultsets.relatedtc = testcases.oid
AND testresultsets.active IS NOT NULL
AND testresults.relatedtestresultset = testresultsets.oid
AND testresults.islastresultforcomp IS NOT NULL
GROUP BY testresults.result
For a chart i also need the missing results 2 and 4 to be shown with 0 counts.
So I decided to combine them in a joint data set(left join):
result|resulttext______|result|count(*)|resulttext
0____|unworked______|0____|5______|unworked
1____|passed________|1____|121____|passed
2____|partially passed_|_____|0______|______
3____|failed__________|3____|21_____|failed
4____|blocked________|_____|0______|______
But there is the problem.
Each dataset individually works without problems and needs not more than 3 seconds for preview. In the joint-dataset-editor I try to preview the results, the progress information window pops up and the progress runs endless.
Also eclipse need nearly 100% prozessor load and I have to shoot up eclipse in the task manager.
Because Im a beginner in scripting in birt I guess the sourcecode above is the problem.
I also tried to combine a second scripted dataset(same values like the sql-dataset) with the first one with the same effect.
If you need the designfile for this problem let me know.
Hope someone can help me.
JasonW
I do not know if this will fix the problem but can you change the code to:
ON OPEN
cnt=0
myarr1[0] = 0;
myarr1[1] = 1;
myarr1[2] = 2;
myarr1[3] = 3;
myarr1[4] = 4;
ON FETCH
if(cnt<parmcount)
cnt++;
return true;
return false;
If you do not return false the dataset will run forever.
Jason
doublehawk
Thank you very much for finging the bug in my code!
I will attach a designfile to this thread for beginners like me, which demostrates a joint dataset with two scripted datasets and a chart with exchanged colors by a script. I guess this will help some guys like me.
