problem with computed column
prashu_444
hi all,
I am retriving qty and status fields from database. if qty field value is 21 and status value is o then data should appear as 21% .if qty field value is 21 and status value is 1 then data should appear as 21 no .
I tried to achive this using computed columns . but its not working.
below is the computed column code ..
if(row["STATUS"]==0
return row["QUANTITY"] + "%" ;
else
return row["QUANTITY"] + " no" ;
any idea what is the problem. ??
or can we achive it in some other way ??
bhanley
The easiest way would be to manipulate the data mapping. I assume you are doing this in a table, so you could make the expression for the data element in the table something like this (where the "ind" column is your 0/1 indicator):<br />
if(dataSetRow["ind"] == 1)
dataSetRow["val"] + "%";
else
dataSetRow["val"] ;
</pre>
Once you add the "val" data to a table, double-click it and edit the expression.<br />
I have also done it using a dynamic text element. The code is logically the same, but syntactically different.<br />
Sample data and report are attached. Put the CSV in C:Data for the report to work as-is.<br />
Good Luck!
