Multi dataset problem?
zerocool
hello all you guyz!
Im using Birt-Eclipse to create report in Maximo,my first one, but i got a trouble and need help, this is it:
i created 2 datasets, one for the master and one for detail
The problem is it work well in the preview but when i imported it into maximo, i can just only see the master records, all the detail record is empty.
Could anyone here give me some suggestion?
SpaceMan
Can you attach the report? If it's BIRT 2.1.2 i can take a look at it.
zerocool
Solved it.
I deleted the report from maximo and import it again, and dont know why...
Thanks, SpaceMan
