Problems with images from shared resources in PDF output
ziploide
Hi everyone!<br />
Like most of the folks here, I'm pretty new to BIRT but have been playing with if for the past few weeks.<br />
I've managed to make awesome reports so easily and in a blink of an eye.<br />
My problems is that reports that I try to generate in PDF format seem to have problems to output the images (Haven't tried charts yet...)<br />
Every time I try to output a PDF report featuring a JPG image, instead of it there's a text saying "Current report item is not supported in this report format." If I use an embedded image the resulting report is normal, but I need the images to be from a shared resource.<br />
This is the configuration of my PDFRenderOption (By the way, I'm using a Servlet whose only purpose is to print the report. It is to be deployed to a Weblogin 9.2 Server. Everything works awesome but the images):<br />
design = birtReportEngine.openReportDesign( sc.getResource("/Reports/"+reportName+".rptdesign").toString().substring(6) );
//create task to run and render report
IRunAndRenderTask task = birtReportEngine.createRunAndRenderTask( design );
task.getAppContext().put("BIRT_VIEWER_HTTPSERVLET_REQUEST", req);
PDFRenderOption options = new PDFRenderOption();
options.setOutputFormat(HTMLRenderOption.OUTPUT_FORMAT_PDF);
resp.setHeader( "Content-Disposition", "inline; filename=""+reportName+".pdf"" );
options.setOutputStream(resp.getOutputStream());
options.setImageHandler(new HTMLServerImageHandler());
task.setRenderOption(options);
//run report
task.run();
task.close();
</pre>
Everything, Images, Report designs is in the WebContent Folder. Images are in WebContent/Images and report designs are in WebContent/Reports.<br />
Hope anyone helps me out with this.
There are no comments yet
