Engine Exception when running some reports
RaviV
I am Using MySQL database, and Tomcat 5.5.
I use Birt viewer runtime ( Birt 2.3 ) and have bundled into a war which I have deployed.
Now, occasionally I get an exception while attempting to run reports via the viewer. ( does not matter which report. Seems to be a bit random. It could be tied to inactivity).
=== Begin Exception Stack Trace ===
org.eclipse.birt.report.engine.api.EngineException:
An exception occurred during processing. Please see the following
message for details:
Cannot get the result set metadata.
SQL statement does not return a ResultSet object.
SQL error #1: No operations allowed after statement closed.
at
org.eclipse.birt.report.engine.executor.ExtendedGenerateExecutor.execute(ExtendedGenerateExecutor.java:70)
at
org.eclipse.birt.report.engine.executor.ExtendedItemExecutor.execute(ExtendedItemExecutor.java:61)
at
org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:45)
=== End Exception Stack trace ===
I think MySQL is dropping connections in the pool maintained by Tomcat?
MYSQL explains a couple of 'fixes'. 1. Set the auto reconnect which is not a great solution and 2. A fix where the caller needs to do a retry, but this code is in Birt.
Is there any other way where I can manipulate from my report and re-execute the report somehow? Is that a solution?
What can I do?
Any ideas?
Ravi
RaviV
I figured it out. This is only for MySQL. Its inactivity period is 8 hours. I needed to add a DBCP setting in the app server. Tomcat (testForBorrow with validationQuery, with some test SQL), JBoss (check-valid-connection-sql, some test SQL) have it. to test a connection before returning from pool. Similar checks are also there in Weblogic and Websphere ( from admin console)
Not a Birt issue.
