Difference between Birt Viewer and Actuate Viewer?
skassam
Is there a big difference between the Birt Viewer and Actuate Viewer? I am not referring to the Interactive Viewer.
Is there any appreciable difference in ability to scale or quality between the two?
TIA.
JasonW
The Actuate viewer contains extra components like the flash report items, it also has nicer excel and pdf emitters (I just did a blog post on the excel emitter
http://birtworld.blogspot.com/2010/06/birt-excel-output.html)
Jason
skassam
<blockquote class='ipsBlockquote' data-author="'JasonW'" data-cid="65689" data-time="1276799001" data-date="17 June 2010 - 11:23 AM"><p>
The Actuate viewer contains extra components like the flash report items, it also has nicer excel and pdf emitters (I just did a blog post on the excel emitter <a class='bbc_url' href='
http://birtworld.blogspot.com/2010/06/birt-excel-output.html'>http://birtworld.blogspot.com/2010/06/birt-excel-output.html</a>)
. <br />
Jason<br /></p></blockquote>
Thanks Jason, Is there any reason to use the Actuate Viewer instead of the free Viewer if we do not need the extra components? Is the free Viewer any lesser in quality regarding the amount of testing it has gone through or it's ability to handle large data sets?<br />
Thanks!
JasonW
Take a look at this page. The Actuate Viewer contains some additional improvements like progressive viewing.
http://www.birt-exchange.com/be/download/Viewer-Product-Comparison-Table.pdf
Jason
