Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
MirelS
After upgrading to BIRT 2.6 we get the below exception when calling design.setDesignHandle(handle);
How can we resolve it?
!ENTRY org.eclipse.ui.workbench 4 2 2010-07-14 09:50:19.602
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 0
java.lang.NullPointerException
at com.cisco.easycopy.actions.EasyCopyAction.selectionChanged(EasyCopyAction.java:114)
at org.eclipse.ui.internal.PluginAction.refreshEnablement(PluginAction.java:206)
at org.eclipse.ui.internal.PluginAction.selectionChanged(PluginAction.java:277)
at org.eclipse.ui.internal.ObjectPluginAction.partClosed(ObjectPluginAction.java:49)
at org.eclipse.ui.internal.PartListenerList2$3.run(PartListenerList2.java:100)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.PartListenerList2.fireEvent(PartListenerList2.java:55)
at org.eclipse.ui.internal.PartListenerList2.firePartClosed(PartListenerList2.java:98)
at org.eclipse.ui.internal.PartService.firePartClosed(PartService.java:227)
at org.eclipse.ui.internal.WorkbenchPagePartList.firePartClosed(WorkbenchPagePartList.java:39)
at org.eclipse.ui.internal.PartList.partClosed(PartList.java:274)
at org.eclipse.ui.internal.PartList.removePart(PartList.java:186)
at org.eclipse.ui.internal.WorkbenchPage.disposePart(WorkbenchPage.java:1714)
at org.eclipse.ui.internal.WorkbenchPage.handleDeferredEvents(WorkbenchPage.java:1422)
at org.eclipse.ui.internal.WorkbenchPage.deferUpdates(WorkbenchPage.java:1406)
at org.eclipse.ui.internal.WorkbenchPage.closeEditors(WorkbenchPage.java:1380)
at org.eclipse.ui.internal.WorkbenchPage.closeEditor(WorkbenchPage.java:1444)
at org.eclipse.debug.internal.ui.sourcelookup.SourceLookupFacility.openEditor(SourceLookupFacility.java:288)
at org.eclipse.debug.internal.ui.sourcelookup.SourceLookupFacility.display(SourceLookupFacility.java:219)
at org.eclipse.debug.ui.DebugUITools.displaySource(DebugUITools.java:792)
at org.eclipse.debug.internal.ui.elements.adapters.StackFrameSourceDisplayAdapter$SourceDisplayJob.runInUIThread(StackFrameSourceDisplayAdapter.java:155)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:95)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3468)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3115)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
!ENTRY org.eclipse.jdt.launching 4 113 2010-07-14 10:49:52.552
!MESSAGE Failed to connect to remote VM. Connection refused.
!STACK 0
java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:529)
at java.net.Socket.connect(Socket.java:478)
at java.net.Socket.<init>(Socket.java:375)
at java.net.Socket.<init>(Socket.java:189)
at org.eclipse.jdi.internal.connect.SocketTransportService$2.run(SocketTransportService.java:136)
at java.lang.Thread.run(Thread.java:619)
Appreciate your help,
Mirel.
JasonW
Mirel,
How did you upgrade? Where are you calling this code:
Jason
wmashal
Hi JasonW <br />
can I answer Mirel
the purpose of our old code is retrieving the data sets we have so we add these lines <br />
we upgrade all jars in lib , plugins and the configuration folder <br />
<strong class='bbc'>ReportDesignHandle handle = (ReportDesignHandle) design.getDesignHandle();<br />
List<DataSourceHandle> dataSources = handle.getAllDataSources();</strong><br />
where design of type IReportRunnable<br />
then we call the <strong class='bbc'>design.setDesignHandle(handle)</strong><br />
the problem is :<br />
the old handle we have is of type <strong class='bbc'>ReportDesignHandle</strong> but the new API in Birt 2.6 receive a handle of type <strong class='bbc'>ReportElementHandle</strong><br />
so my question how we can modify this code to get getAllDataSources from the ReportElementHandle ?<br />
Best Regards
