Problem with "Web Viewer"
blub1.0
Hello, I?m searching for an expert, who can help me with chart-scripting.
I have a code, which creates 2 MarkerLines and scales the y-axis. This works very good in the preview and on the ?View Report as HTML? or ?View Report as PDF?.
My Problem is: It didn't work on the ?View Report in Web Viewer?.
It looks like the GlobalVariable is ?null?.
Code:
icsc.getExternalContext().getScriptable().getGlobalVariable("maximum");
Why does it work in 3 of 4 cases?
Has anyone an idea?
Thanks a lot for your help.
kosta
Hello blub1.0,
I have another question:
what do you mean by: "I have a code, which creates 2 MarkerLines and scales the y-axis"?
Do you create them programmatically. How do you do that?
Regards,
Kosta
blub1.0
Hello kosta,<br />
this is my chart-script:<br />
<p class='bbc_indent' style='margin-left: 40px;'><span style='color: #4169E1'>function beforeGeneration( chart, icsc )<br />
{<br />
importPackage(Packages.org.eclipse.birt.chart.model.component.impl);<br />
importPackage(Packages.org.eclipse.birt.chart.model.data.impl);<br />
importPackage(Packages.org.eclipse.birt.chart.model.attribute);<br />
importPackage(Packages.org.eclipse.birt.chart.model.attribute.impl);<br />
var chart = icsc.getChartInstance();<br />
var yAxis = chart.getAxes().get(0).getAssociatedAxes().get(0);<br />
var min_value = icsc.getExternalContext().getScriptable().getPersistentGlobalVariable("mini");<br />
var max_value = icsc.getExternalContext().getScriptable().getPersistentGlobalVariable("maxi");<br />
var max_max = icsc.getExternalContext().getScriptable().getGlobalVariable("maximum");<br />
min_ml = MarkerLineImpl.create(yAxis, NumberDataElementImpl.create(min_value));<br />
max_ml = MarkerLineImpl.create(yAxis, NumberDataElementImpl.create(max_value));<br />
//label, color and style of the markers<br />
min_ml.getLabel().getCaption().setValue(" ");<br />
max_ml.getLabel().getCaption().setValue(" ");<br />
min_ml.getLineAttributes().getColor().set(0,128,0);<br />
max_ml.getLineAttributes().getColor().set(255,0,0);<br />
min_ml.getLineAttributes().setStyle(LineStyle.SOLID_LITERAL);<br />
max_ml.getLineAttributes().setStyle(LineStyle.SOLID_LITERAL);<br />
min_ml.getLineAttributes().setThickness(2); //Dicke des Balkens<br />
max_ml.getLineAttributes().setThickness(2); //Dicke des Balkens<br />
//scales the y-axis<br />
xAxis = chart.getBaseAxes()[0]; <br />
yAxis = chart.getOrthogonalAxes( xAxis, true)[0];<br />
yscale = yAxis.getScale(); <br />
yscale.setMin( NumberDataElementImpl.create(0)) ;<br />
yscale.setMax( NumberDataElementImpl.create(max_max));<br />
yAxis.setScale(yscale);<br />
}</span></p>
The variables mini and maxi are values from a aggregation of a table. <br />
Maximum is calculated on the table-script.<br />
By blub1.0
blub1.0
Hello,
okay I have a solution.
I have to find out that in charts PersistentGlobalVariable work, but GlobalVariable don?t work.
Because it don?t work to write a local variable in a PersistentGlobalVariable, I writing it in a table (this.setDisplayValue(xyz)). After this I write the value of this cell in an PersistentGlobalVariable (reportContext.setPersistentGlobalVariable("maximum",this.getValue())).
This isn?t very elegant, but it works!
Thanks at all who read my question.
