Hi All,<br />
I have a table in MS SQL say "sriraman_test". There are two columns one with "Name" varchar and other with the "DATETIME" as datetime (8/26/2010 1:03:34 PM format). A similar table also exists in oracle with the timestamp (01-Sep-10 01:00:00.000000 PM format)instead of datetime.<br />
1. <strong class='bbc'><em class='bbc'>With birt version 2.2.1 I am not able to create a report for the below select query</em></strong><br />
"select * from DASH1.SRIRAMAN_TEST where DASH1.SRIRAMAN_TEST.DATETIME = ?". I get an error message as below<br />
The following items have errors: <br />
ReportDesign (id = 1): <br />
+ Cannot get the result set metadata.<br />
SQL statement does not return a ResultSet object.<br />
SQL error #1: ORA-01843: not a valid month<br />
<em class='bbc'><strong class='bbc'>However with birt version 2.6, I am able to create a proper report for the query above.</strong></em><br />
2. <em class='bbc'><strong class='bbc'>However for similar query on MS SQL I am able to create a report in version 2.2.1 but in version 2.6 same query fails i.e. I dont get any error messages, but the report is blank though I have proper values which should come up on report.</strong></em> The query for MS SQL is as below<br />
"select * from dbo.sriraman_test where dbo.sriraman_test.DATETIME = ?"<br />
Below are the design files. I have to paste here since I am unable to attach them. <br />
===========================================================================================<br />
<strong class='bbc'><em class='bbc'>mssql_datetime_2_2_1</em></strong><br />
[xml]<br />
<?xml version="1.0" encoding="UTF-8"?><br />
<report xmlns="http-~~-//www.eclipse.org/birt/2005/design" version="3.2.15" id="1"><br />
<property name="createdBy">Eclipse BIRT Designer Version 2.2.1.r221_v20070924 Build <2.2.0.v20070924-1550></property><br />
<property name="units">in</property><br />
<property name="comments">Copyright (c) 2007 <<Your Company Name here>></property><br />
<html-property name="description">Creates a blank report with no predefined content.</html-property><br />
<text-property name="displayName">Blank Report</text-property><br />
<property name="iconFile">/templates/blank_report.gif</property><br />
<parameters><br />
<scalar-parameter name="param_1" id="24"><br />
<property name="valueType">static</property><br />
<property name="dataType">dateTime</property><br />
<property name="paramType">simple</property><br />
<property name="isRequired">true</property><br />
<property name="controlType">text-box</property><br />
<property name="defaultValue">08/26/2010 01:03:34 PM</property><br />
<property name="distinct">true</property><br />
<structure name="format"><br />
<property name="category">Unformatted</property><br />
</structure><br />
</scalar-parameter><br />
</parameters><br />
<data-sources><br />
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source" id="6"><br />
<text-property name="displayName"></text-property><br />
<list-property name="privateDriverProperties"><br />
<ex-property><br />
<name>ODAPerspective</name><br />
<value>Birt</value><br />
</ex-property><br />
<ex-property><br />
<name>ODAUsageHelperConnection</name><br />
<value>Native</value><br />
</list-property><br />
<property name="odaDriverClass">net.sourceforge.jtds.jdbc.Driver</property><br />
<property name="odaURL">jdbc:jtds:sqlserver://10.113.58.41/dash1;Instance=;PrepareSQL=0</property><br />
<property name="odaUser">sa</property><br />
<encrypted-property name="odaPassword" encryptionID="base64">d2VsY29tZQ==</encrypted-property><br />
</oda-data-source><br />
</data-sources><br />
<data-sets><br />
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" name="Data Set" id="7"><br />
<list-property name="columnHints"><br />
<structure><br />
<property name="columnName">name</property><br />
<property name="displayName">name</property><br />
</structure><br />
<structure><br />
<property name="columnName">datetime</property><br />
<property name="displayName">datetime</property><br />
</structure><br />
<structure name="cachedMetaData"><br />
<list-property name="resultSet"><br />
<structure><br />
<property name="position">1</property><br />
<property name="name">name</property><br />
<property name="dataType">string</property><br />
</structure><br />
<structure><br />
<property name="position">2</property><br />
<property name="name">datetime</property><br />
<property name="dataType">date-time</property><br />
</structure><br />
</structure><br />
<property name="dataSource">Data Source</property><br />
<list-property name="parameters"><br />
<structure><br />
<property name="name">param_1</property><br />
<property name="paramName">param_1</property><br />
<property name="nativeName"></property><br />
<property name="nativeDataType">1</property><br />
<property name="isOptional">false</property><br />
<property name="allowNull">false</property><br />
<property name="isInput">true</property><br />
<property name="isOutput">false</property><br />
</structure><br />
<structure><br />
<property name="nativeName">name</property><br />
<property name="nativeDataType">12</property><br />
</structure><br />
<structure><br />
<property name="nativeName">datetime</property><br />
<property name="nativeDataType">93</property><br />
</structure><br />
<property name="queryText">select *<br />
from dbo.sriraman_test<br />
where dbo.sriraman_test.DATETIME = ?</property><br />
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?><br />
<model:DesignValues xmlns:design="http-~~-//www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http-~~-//www.eclipse.org/birt/report/model/adapter/odaModel"><br />
<Version>1.0</Version><br />
<design:DataSetParameters><br />
<design:parameterDefinitions><br />
<design:inOutMode>In</design:inOutMode><br />
<design:attributes><br />
<design:name></design:name><br />
<design:position>1</design:position><br />
<design:nativeDataTypeCode>1</design:nativeDataTypeCode><br />
<design:nullability>Unknown</design:nullability><br />
<design:uiHints/><br />
</design:attributes><br />
<design:inputAttributes><br />
<design:elementAttributes><br />
<design:defaultScalarValue>08/26/2010 01:03:34 PM</design:defaultScalarValue><br />
<design:optional>false</design:optional><br />
<design:masksValue>false</design:masksValue><br />
<design:uiHints><br />
<design:promptStyle>TextField</design:promptStyle><br />
</design:uiHints><br />
</design:elementAttributes><br />
</design:inputAttributes><br />
</design:parameterDefinitions><br />
</design:DataSetParameters><br />
<design:ResultSets derivedMetaData="true"><br />
<design:resultSetDefinitions><br />
<design:resultSetColumns><br />
<design:resultColumnDefinitions><br />
<design:name>name</design:name><br />
<design:nativeDataTypeCode>12</design:nativeDataTypeCode><br />
<design:precision>50</design:precision><br />
<design:scale>0</design:scale><br />
<design:nullability>Nullable</design:nullability><br />
<design:displayName>name</design:displayName><br />
<design:usageHints><br />
<design:label>name</design:label><br />
<design:formattingHints><br />
<design:displaySize>50</design:displaySize><br />
</design:formattingHints><br />
</design:usageHints><br />
</design:resultColumnDefinitions><br />
<design:name>datetime</design:name><br />
<design:position>2</design:position><br />
<design:nativeDataTypeCode>93</design:nativeDataTypeCode><br />
<design:precision>23</design:precision><br />
<design:scale>3</design:scale><br />
<design:displayName>datetime</design:displayName><br />
<design:label>datetime</design:label><br />
<design:displaySize>23</design:displaySize><br />
</design:resultSetColumns><br />
</design:resultSetDefinitions><br />
</design:ResultSets><br />
</model:DesignValues>]]></xml-property><br />
</oda-data-set><br />
</data-sets><br />
<styles><br />
<style name="crosstab-cell" id="4"><br />
<property name="borderBottomColor">#CCCCCC</property><br />
<property name="borderBottomStyle">solid</property><br />
<property name="borderBottomWidth">1pt</property><br />
<property name="borderLeftColor">#CCCCCC</property><br />
<property name="borderLeftStyle">solid</property><br />
<property name="borderLeftWidth">1pt</property><br />
<property name="borderRightColor">#CCCCCC</property><br />
<property name="borderRightStyle">solid</property><br />
<property name="borderRightWidth">1pt</property><br />
<property name="borderTopColor">#CCCCCC</property><br />
<property name="borderTopStyle">solid</property><br />
<property name="borderTopWidth">1pt</property><br />
</style><br />
<style name="crosstab" id="5"><br />
</style><br />
</styles><br />
<page-setup><br />
<simple-master-page name="Simple MasterPage" id="2"><br />
<page-footer><br />
<text id="3"><br />
<property name="contentType">html</property><br />
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property><br />
</text><br />
</page-footer><br />
</simple-master-page><br />
</page-setup><br />
<body><br />
<table id="8"><br />
<property name="width">100%</property><br />
<property name="dataSet">Data Set</property><br />
<list-property name="boundDataColumns"><br />
<structure><br />
<expression name="expression">dataSetRow["name"]</expression><br />
</structure><br />
<structure><br />
<expression name="expression">dataSetRow["datetime"]</expression><br />
</structure><br />
<column id="22"/><br />
<column id="23"/><br />
<header><br />
<row id="9"><br />
<cell id="10"><br />
<label id="11"><br />
<text-property name="text">name</text-property><br />
</label><br />
</cell><br />
<cell id="12"><br />
<label id="13"><br />
<text-property name="text">datetime</text-property><br />
</label><br />
</cell><br />
</row><br />
</header><br />
<detail><br />
<row id="14"><br />
<cell id="15"><br />
<data id="16"><br />
<property name="resultSetColumn">name</property><br />
</data><br />
</cell><br />
<cell id="17"><br />
<data id="18"><br />
<property name="resultSetColumn">datetime</property><br />
</data><br />
</cell><br />
</row><br />
</detail><br />
<footer><br />
<row id="19"><br />
<cell id="20"/><br />
<cell id="21"/><br />
</row><br />
</footer><br />
</table><br />
</body><br />
</report><br />
[/xml]<br />
<strong class='bbc'><em class='bbc'>mssql_datetime_2_6</em></strong><br />
[xml]<br />
<report xmlns="http-~~-//www.eclipse.org/birt/2005/design" version="3.2.21" id="1"><br />
<property name="createdBy">Eclipse BIRT Designer Version 2.6.0.v20100531 Build <2.6.0.v20100609-1613></property><br />
<property name="layoutPreference">auto layout</property><br />
<parameters><br />
<scalar-parameter name="NewParameter" id="42"><br />
<simple-property-list name="defaultValue"><br />
<value type="constant">2010-08-26 15:03:34</value><br />
</simple-property-list><br />
</structure><br />
</parameters><br />
<ex-property><br />
<ex-property><br />
<data-sets><br />
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" name="Data Set" id="25"><br />
<structure><br />
<property name="columnName">Name</property><br />
<text-property name="displayName">Name</text-property><br />
<text-property name="heading">Name</text-property><br />
<property name="displayLength">50</property><br />
<property name="horizontalAlign">justify</property><br />
<property name="wordWrap">false</property><br />
</structure><br />
<structure><br />
<property name="columnName">DATETIME</property><br />
<text-property name="displayName">DATETIME</text-property><br />
<text-property name="heading">DATETIME</text-property><br />
<property name="displayLength">23</property><br />
</structure><br />
<structure><br />
<property name="paramName">NewParameter</property><br />
</structure><br />
<structure><br />
<property name="name">Name</property><br />
</structure><br />
<structure><br />
<property name="name">DATETIME</property><br />
</structure><br />
</structure><br />
<structure><br />
<property name="nativeName">Name</property><br />
</structure><br />
<structure><br />
<property name="nativeName">DATETIME</property><br />
</structure><br />
<xml-property name="queryText"><![CDATA[select *<br />
where dbo.sriraman_test.DATETIME = ?]]></xml-property><br />
<design:precision>38</design:precision><br />
<design:name>Name</design:name><br />
<design:displayName>Name</design:displayName><br />
<design:label>Name</design:label><br />
<design:name>DATETIME</design:name><br />
<design:displayName>DATETIME</design:displayName><br />
<design:label>DATETIME</design:label><br />
<design:criteria/><br />
</data-sets><br />
<styles><br />
</style><br />
</style><br />
</styles><br />
<page-setup><br />
<property name="topMargin">1in</property><br />
<property name="leftMargin">1.25in</property><br />
<property name="bottomMargin">1in</property><br />
<property name="rightMargin">1.25in</property><br />
<page-footer><br />
<text id="3"><br />
</text><br />
</page-setup><br />
<body><br />
<table id="43"><br />
<structure><br />
<expression name="expression" type="javascript">dataSetRow["Name"]</expression><br />
</structure><br />
<structure><br />
<expression name="expression" type="javascript">dataSetRow["DATETIME"]</expression><br />
</structure><br />
<column id="57"/><br />
<column id="58"/><br />
<header><br />
<row id="44"><br />
<cell id="45"><br />
<label id="46"><br />
<text-property name="text">Name</text-property><br />
</label><br />
</cell><br />
<cell id="47"><br />
<label id="48"><br />
<text-property name="text">DATETIME</text-property><br />
</label><br />
</cell><br />
</row><br />
</header><br />
<detail><br />
<row id="49"><br />
<cell id="50"><br />
<data id="51"><br />
<property name="whiteSpace">nowrap</property><br />
<property name="resultSetColumn">Name</property><br />
</data><br />
</cell><br />
<cell id="52"><br />
<data id="53"><br />
<property name="resultSetColumn">DATETIME</property><br />
</data><br />
</cell><br />
</row><br />
</detail><br />
<footer><br />
<row id="54"><br />
<cell id="55"/><br />
<cell id="56"/><br />
</row><br />
</footer><br />
</table><br />
</body><br />
</report><br />
[/xml]<br />
<strong class='bbc'><em class='bbc'>oracle_timestamp_2_2_1</em></strong><br />
[xml]<br />
<parameters><br />
<property name="defaultValue">09/01/2010 03.59.00 PM</property><br />
</structure><br />
</parameters><br />
<ex-property><br />
<ex-property><br />
<property name="odaDriverClass">oracle.jdbc.OracleDriver</property><br />
<property name="odaURL">jdbc:oracle:thin:
@10.113.57.248:1521:sriraman</property><br />
<property name="odaUser">dash1</property><br />
<encrypted-property name="odaPassword" encryptionID="base64">ZGFzaDE=</encrypted-property><br />
<data-sets><br />
<structure name="cachedMetaData"/><br />
<structure><br />
</structure><br />
from DASH1.SRIRAMAN_TEST<br />
where DASH1.SRIRAMAN_TEST.DATETIME = ?</property><br />
<design:defaultScalarValue>09/01/2010 03.59.00 PM</design:defaultScalarValue><br />
<design:precision>4000</design:precision><br />
<design:displaySize>4000</design:displaySize><br />
<design:precision>0</design:precision><br />
<design:scale>6</design:scale><br />
<design:displaySize>11</design:displaySize><br />
</data-sets><br />
<styles><br />
</style><br />
</style><br />
</styles><br />
<page-setup><br />
<page-footer><br />
<text id="3"><br />
</text><br />
</page-setup><br />
<body><br />
<structure><br />
</structure><br />
<structure><br />
</structure><br />
<header><br />
<row id="9"><br />
</label><br />
</cell><br />
</label><br />
</cell><br />
</row><br />
</header><br />
<detail><br />
<row id="14"><br />
</data><br />
</cell><br />
</data><br />
</cell><br />
</row><br />
</detail><br />
<footer><br />
<row id="19"><br />
</row><br />
</footer><br />
</table><br />
</body><br />
</report><br />
[/xml]<br />
<strong class='bbc'><em class='bbc'>oracle_timestamp_2_6</em></strong><br />
[xml]<br />
<property name="bidiLayoutOrientation">ltr</property><br />
<property name="imageDPI">96</property><br />
<parameters><br />
<scalar-parameter name="NewParameter2" id="25"><br />
<value type="constant">2010-09-01 15:59:00</value><br />
</structure><br />
</parameters><br />
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source" id="7"><br />
<ex-property><br />
<name>contentBidiFormatStr</name><br />
<value>ILYNN</value><br />
<ex-property><br />
<name>metadataBidiFormatStr</name><br />
<data-sets><br />
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" name="Data Set" id="8"><br />
<structure><br />
<property name="paramName">NewParameter2</property><br />
</structure><br />
<structure><br />
<property name="name">NAME</property><br />
</structure><br />
<structure><br />
</structure><br />
</structure><br />
<structure><br />
<property name="nativeName">NAME</property><br />
</structure><br />
<structure><br />
</structure><br />
where SRIRAMAN_TEST.DATETIME = ?]]></xml-property><br />
<design:name>NAME</design:name><br />
<design:displayName>NAME</design:displayName><br />
<design:label>NAME</design:label><br />
