Multi level library problem
szopkoa
Hi all,
we've got a serious problem (version 2.6.1), which we could not solve. Our reports use multi level libraries, and those work fine in the designer, though fail to run on the application server - on which we use the run and render tasks separately.
The problem occurs when a report design refers to an element in the library, which use a data source (it runs fine in the designer).
- The data source is fine, because data sets defined in the report design works well using the referred data source
- If I put the data source directly in the library/report design, the report still fails to run with a referred data set
Data set is fine as well, because I could make it run by copying it to the report design - but it is not a solution, since the reusability is lost.
I can attach a simplified example, or post the stacktrace if any of those might serve a better understanding of the above.
Cheers,
Andras
szopkoa
I wrote the above comment after 3 days trying, but now the problem seems to be the following:
- we wrote the report libraries in a text editor, not to let the designer put any unnecessary code into it
- somehow the element ids were messed up (at least that's what I can think of, although the uniqueness was preserved)
For now it appears that rebuilding the libraries in the designer (and than cleansing the code in a text editor) solved the problem.
Cheers,
Andras
