Not able to modify legend entry for a chart before Rendering
pratim
I want to change the legend entry for a line chart dynamically.
To start with, i tried whether i can change the legend item at all or not !!, as shown below,
function beforeDrawLegendItem( lerh, bounds, icsc )
lerh.getLabel().getCaption().setValue("test");
But, the above code does not change my line chart legend into "test".
Legend entries are still displaying the values as per "optional y-axis grouping".
I am using BIRT 2.3.2.
Can anyone help me out?
mwilliams
Hi pratim,
I know things don't work correctly with labels when y-series grouping is enabled. I can't rememeber if there is a way around this. I'll have to check it out in 2.3.2 and then in the latest version to see if anything has changed. If not, I'll have you log a bug for it.
pratim
Hi Michale,<br />
Thanks for the quick reply, it will be great help if you can confirm anything on this issue.<br />
<blockquote class='ipsBlockquote' data-author="'mwilliams'" data-cid="73044" data-time="1297173656" data-date="08 February 2011 - 07:00 AM"><p>
Hi pratim,<br />
I know things don't work correctly with labels when y-series grouping is enabled. I can't rememeber if there is a way around this. I'll have to check it out in 2.3.2 and then in the latest version to see if anything has changed. If not, I'll have you log a bug for it.<br /></p></blockquote>
mwilliams
Can you reproduce the issue with the sample database and post it in here? I used y-series grouping and was able to change all of the legend label values to "blah".
mwilliams
That was in 2.3.2 as well, btw.
