Hello fellow Birters,<br />
I'm trying to create a driver and designer plug-in but is stuck on the Data Set Wizard. Both plug-ins are created by the standard wizard "File/New.../Project/Buisiness Intelligence and Reporting Tools/ODA Designer Plug-in Project" and "ODA Runtime Driver Plug-in Project".<br />
When running the designer plug-in as Eclipse Application it works fine to add the new data source to a report (it shows up nicely with two properties), but when creating a data set, my data set is showing up and can be selected, but you can press "Next" to proceed to my custom data set ui.<br />
Could any one help me with this?<br />
I have tried to work with the extensions in the designer ui, but no luck. Also, I'm using Eclipse 3.5.<br />
Thanks<br />
Carl<br />
EDIT: Test case would be to create a new driver and designer plug-in and run the designer as Eclipse Application. Create a report, the data source (no problems) and then add a data set (not working).<br />
SOLVED:<br />
<img src='
http://i.imgur.com/a8hP9.png' alt='Posted Image' class='bbc_img' /><br />
It's very important to type the correct values here! The driver class and data set element id have some sort of formula that is "driver-symbolic-name" + ".impl.Driver" and + ".dataset".<br />
The driver-symbolic-name can be found in the drivers manifest.
