Problem while running report
gowthamkar
I have developed a report proj in actuate 11 birt designer professional and i copied it in the actuate 10 birt report designer professional. while i am trying to open the report in actuate 10 i am getting the following warning.....
"The report file of version 3.2.22 is not supported"
and while running it displaying a error msg:
" The report file of version "3.2.22" is invalid for it is greater than the latest supported one."
please help me to resolve this problem.
thank you in advance
JasonW
I do not believe Actuate 11 reports are not backwards compatible. If you did not use any specific 11 features you may be able to manually change the version number in the xml to the A10 version and reload it.
Jason
