Chart Display Problem on WebSphere 6.1
lenburt
Hello - we have been developing and deploying Eclipse BIRT reports for a few months and have them running fine under Tomcat. Our true deployment platform will be WebSphere 6.1. I have been able to get the basic 'text' reports to work fine but any of our graph reports fail with this error written to SystemOut.log. The class mentioned seems to exist in a jar in the correct location but it obviously is not happy with something...any ideas?
[5/19/11 19:01:21:218 EDT] 0000002a ServletWrappe E SRVE0068E: Uncaught exception thrown in one of the service methods of the servlet: ViewerServlet. Exception thrown : java.lang.NoClassDefFoundError: org.eclipse.birt.chart.model.impl.SerializerImpl (initialization failure)
at java.lang.J9VMInternals.initialize(J9VMInternals.java:123)
at org.eclipse.birt.chart.reportitem.ChartReportItemFactoryBase.createSerializer(ChartReportItemFactoryBase.java:51)
at org.eclipse.birt.chart.reportitem.ChartReportItemUtil.instanceSerializer(ChartReportItemUtil.java:281)
at org.eclipse.birt.chart.reportitem.ChartReportItemImpl.<init>(ChartReportItemImpl.java:163)
One additional bit of information:
When i start the application i get a few messages about plugins...i do not see any other detailed information about these so i am not sure if they are related to my issue.
Is it safe to assume that many others have deployed BIRT charts to WebSphere 6.1 on Windows XP?
5/24/11 10:28:42:612 PDT] 00000027 ApplicationMg A WSVR0200I: Starting application: birt_war
[5/24/11 10:28:42:628 PDT] 00000027 ApplicationMg A WSVR0204I: Application: birt_war Application build level: Unknown
[5/24/11 10:28:42:831 PDT] 00000027 ExtensionRegi E CWXRS0004E: Failed to resolve plug-in
[5/24/11 10:28:42:847 PDT] 00000027 ExtensionRegi E CWXRS0004E: Failed to resolve plug-in
lenburt
This is additional information about the issue.
I notice that when i start the application i get messages about missing Plugins -- not sure if this is related.
Is it safe to assume that many folks have successfully deployed BIRT chart reports to WebSphere 6.1 on Windows XP?
[5/24/11 10:28:36:665 PDT] 00000027 WebContainer E SRVE0255E: A WebGroup/Virtual Host to handle /favicon.ico has not been defined.
[5/24/11 10:28:40:484 PDT] 00000027 WebApp A SRVE0180I: [isclite#isclite.war] [/ibm/console] [Servlet.LOG]: action: ApplicationDeploymentDetailForm was null.Creating new form bean and storing in session
[5/24/11 10:28:42:612 PDT] 00000027 ApplicationMg A WSVR0200I: Starting application: birt_war
[5/24/11 10:28:42:878 PDT] 00000027 WebGroup A SRVE0169I: Loading Web Module: Eclipse BIRT Report Viewer.
[5/24/11 10:28:45:539 PDT] 00000027 VirtualHost I SRVE0250I: Web Module Eclipse BIRT Report Viewer has been bound to default_host[*:9080,*:80,*:9443,*:5060,*:5061,*:443].
[5/24/11 10:28:45:554 PDT] 00000027 ApplicationMg A WSVR0221I: Application started: birt_war
averma
Hi lenburt,
What version of BIRT are you working with? Can you follow the recommendations here and give it one more try?
http://wiki.eclipse.org/Birt_WebSphere_Deployment
Ashwini
lenburt
Ashwini
I am using the 2.6.2 BIRT runtime. I did see that posting but it was for WAS 5.1 and 6.01. I was hoping i did not have to build my own ear but if you think that will work i will try that. I was surprised that there was not a WAS 6.1 section since that has been out for quite a while. The link also references BIRT 2.1.1 so i figured it was way out of date.
I will try to build and deploy an EAR and see if that corrects the problem. - thx, len
lenburt
Success! -- the tip on setting the Class Loader Mode seems to resolve the problem. The tip says the mode should be 'parent last'; In the 6.1 console i think that means 'application first' -- anyway, charts appear now!
averma
Can you report a bug on bugzilla?
http://www.eclipse.org/birt/phoenix/reportabug.php
lenburt
<blockquote class='ipsBlockquote' data-author="'averma'" data-cid="77973" data-time="1307136517" data-date="03 June 2011 - 02:28 PM"><p>
Can you report a bug on bugzilla?<br /></p></blockquote>
