currentcy format issue for loss or negative values
Atar Singh
In mycurrent report,I have to set currency as($ 1000) for negative vlaues. While i ended up showing
like $(1000) .
Could you please suggest,How can i show loss or negative values like ($ 1000) ?
Atar Singh
mwilliams
One thing you could do would be to create a computed column in your dataSet that creates a string representation of your currency values for display in your report. Something like:
if (row["myRow"] < 0){
"($ " + row["myRow"].toString() + ")";
else{
row["myRow"].toString();
Or something like that. You can still do any other computations with your original field.
Suneel Mac
It is working fine for only data set columns... I need the same format for aggregation also...
Could you please suggest,How can i show?
mwilliams
Delete the aggregation element and use a text or dynamic textbox instead to format the display of your aggregation value.
Atar Singh
Thanks a lot, This issue is resolved.
Atar Singh
Solution :
I did not use any script rather,
1. Selected "Format Number"
2. Format as "Custom" and in
3. Format Code added "($##,##0)"
Atar Singh
mwilliams
Not all numbers had the () around them with that format? Just the negatives? If so, I learned something new today! I thought about that but figured it would show the () for all values.
