Dear All<br />
I am new to the BIRT realm.. I just installed eclipse indigo version with the BIRT designer. I then created a report and got it connected to a mysql database at design time. When i preview the report in the IDE, it works all fine and all the data appear.<br />
I then decided to use the report using BIRT Report Viewer obtained from birt-runtime-3_7_0. So i installed Tomcat 5.5 and in its webapp folder i hosted the BIRT Viewer Folder. I reran tomcat and the example test report supplied with the viewer worked fine. So i decided to try my report created using the IDE. What i did is that i copied and pasted the report file, called <em class='bbc'>lstMembers.rptdesign</em>, in the report viewer folder, just next to the test report called <em class='bbc'>test.rptdesign</em>. <br />
I read somewhere that i needed to copy the drivers in the <em class='bbc'>WEB-INF\lib</em> folder of the viewer. So i pasted the file <em class='bbc'>mysql-connector-java-5.1.17-bin</em> there and reran tomcat.<br />
Yet, When i ran the report using the url: <br />
<em class='bbc'>
http://localhost:8081/WebViewerExample/run?__report=lstMembers.rptdesign</em><br />
I get the following error:<br />
<span style='color: #FF0000'>The following items have errors:<br />
Table (id = 38):<br />
- An exception occurred during processing. Please see the following message for details:<br />
Cannot open the connection for the driver: org.eclipse.birt.report.data.oda.jdbc.dbprofile.<br />
org.eclipse.datatools.connectivity.oda.OdaException ;<br />
java.lang.NullPointerException (Element ID:38)<br />
exception.error ( 1 time(s) )<br />
detail : org.eclipse.birt.report.engine.api.EngineException: An exception occurred during processing. Please see the following message for details:<br />
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1206)<br />
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1185)<br />
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:96)<br />
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)<br />
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)<br />
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)<br />
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)<br />
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)<br />
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)<br />
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)<br />
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:180)<br />
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)<br />
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:929)<br />
at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)<br />
at org.eclipse.birt.report.service.actionhandler.BirtGetPageAllActionHandler.__execute(BirtGetPageAllActionHandler.java:131)<br />
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)<br />
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)<br />
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)<br />
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPageAll(BirtDocumentProcessor.java:183)<br />
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)<br />
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)<br />
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)<br />
at java.lang.reflect.Method.invoke(Unknown Source)<br />
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)<br />
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)<br />
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)<br />
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)<br />
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)<br />
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)<br />
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)<br />
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)<br />
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)<br />
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)<br />
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)<br />
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)<br />
at javax.servlet.http.HttpServlet.service(HttpServlet.java:647)<br />
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)<br />
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)<br />
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)<br />
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)<br />
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)<br />
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerFilter.java:68)<br />
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)<br />
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)<br />
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:172)<br />
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)<br />
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)<br />
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)<br />
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)<br />
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:879)<br />
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)<br />
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)<br />
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)<br />
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)<br />
at java.lang.Thread.run(Unknown Source)<br />
Caused by: org.eclipse.birt.report.data.adapter.api.AdapterException: An exception occurred during processing. Please see the following message for details:<br />
java.lang.NullPointerException<br />
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:636)<br />
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:152)<br />
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:265)<br />
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1897)<br />
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)<br />
... 57 more<br />
Caused by: org.eclipse.birt.data.engine.odaconsumer.OdaDataException: Cannot open the connection for the driver: org.eclipse.birt.report.data.oda.jdbc.dbprofile.<br />
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.newException(ExceptionHandler.java:54)<br />
at org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.openConnection(ConnectionManager.java:177)<br />
at org.eclipse.birt.data.engine.executor.DataSource.newConnection(DataSource.java:224)<br />
at org.eclipse.birt.data.engine.executor.DataSource.open(DataSource.java:212)<br />
at org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiDataSource(DataSourceRuntime.java:217)<br />
at org.eclipse.birt.data.engine.impl.QueryExecutor.openDataSource(QueryExecutor.java:409)<br />
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:319)<br />
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(PreparedQuery.java:455)<br />
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.produceQueryResults(PreparedDataSourceQuery.java:190)<br />
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:178)<br />
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute(PreparedOdaDSQuery.java:145)<br />
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:616)<br />
... 61 more<br />
Caused by: org.eclipse.datatools.connectivity.oda.OdaException ;<br />
at org.eclipse.birt.report.data.oda.jdbc.dbprofile.impl.Connection.open(Connection.java:113)<br />
at org.eclipse.birt.report.data.oda.jdbc.dbprofile.impl.Connection.open(Connection.java:57)<br />
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaConnection.open(OdaConnection.java:250)<br />
at org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.openConnection(ConnectionManager.java:165)<br />
... 71 more<br />
Caused by: java.lang.NullPointerException<br />
at org.eclipse.datatools.connectivity.drivers.jdbc.JDBCConnection.open(JDBCConnection.java:76)<br />
at org.eclipse.datatools.enablement.internal.mysql.connection.JDBCMySQLConnectionFactory.createConnection(JDBCMySQLConnectionFactory.java:28)<br />
at org.eclipse.datatools.connectivity.internal.ConnectionFactoryProvider.createConnection(ConnectionFactoryProvider.java:83)<br />
at org.eclipse.datatools.connectivity.internal.ConnectionProfile.createConnection(ConnectionProfile.java:359)<br />
at org.eclipse.datatools.connectivity.sqm.internal.core.connection.ConnectionInfoImpl.initializeJDBCConnection(ConnectionInfoImpl.java:659)<br />
at org.eclipse.datatools.connectivity.sqm.internal.core.connection.ConnectionInfoImpl.<init>(ConnectionInfoImpl.java:644)<br />
at org.eclipse.datatools.connectivity.sqm.internal.core.connection.ConnectionFactory.createConnection(ConnectionFactory.java:38)<br />
at org.eclipse.datatools.connectivity.sqm.core.SQMConnectionFactory.createConnection(SQMConnectionFactory.java:45)<br />
at org.eclipse.datatools.connectivity.sqm.internal.core.connection.ConnectionFactory.createConnection(ConnectionFactory.java:59)<br />
at org.eclipse.datatools.connectivity.internal.ConnectionFactoryAdapterProvider.createConnection(ConnectionFactoryAdapterProvider.java:114)<br />
at org.eclipse.datatools.connectivity.internal.ManagedConnection.createConnection(ManagedConnection.java:163)<br />
at org.eclipse.datatools.connectivity.internal.CreateConnectionJob.run(CreateConnectionJob.java:56)<br />
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)</span><br />
Can anyone please please help me here?<br />
I have tried hard to get it to work but i simply cant figure out what the problem is<br />
Please help..
