We have developed an ODA extension in which the ODA runtime data source has a parameter say p1. This data source is included in a rptlibrary which itself is included in an rptdesign file. Now setting the data source property p1 using java using the design handle code as mentioned here
http://wiki.eclipse.org/Java_-_Build_Dynamic_Table_(BIRT) and
http://www.birt-exchange.org/org/forum/index.php/topic/21282-change-birt-build-dynamic-table-deapis-datasource-to-informix-database/ does not work as 'p1' isn't reflected anywhere. i.e. when we try to fetch the property p1 from the properties object which is passed as a parameter in the Connection.java class in ODA runtime, it returns null.
would be great if somebody can suggest where are we going wrong.
To add to the info: the rptdesign file opened as a report runnable doesn't have data source configured it inherits the DS from the rptlibrary.
Thanks.
