I am attempting to use a sql server stored procedure in my data set. This is my first attempt at using a stored procedure. The stored procedure I am using has 5 input parameters. They are:
create procedure [dbo].[getUnitOnOffDuty] (
@startDate varchar(100),
@endDate varchar(100),
@tenantId varchar(255),
@unitOrg varchar(500),
@unitName varchar(255))
I want to populate these values using report parameters.
I created the dataset and this is my queryset
call dbo.getUnitOnOffDuty(?,?,?,?,?);
These seems to work fine. When I got the parameters panel, I attempt to use the link to report parameter. It appears to work fine until I hit ok after I have linked all of them. I get the following error:
A BIRT exception occurred.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Data Engine
Plug-in ID:org.eclipse.birt.data
Version:2.6.2.r262_v20110215
Error Code:data.engine.fail.prepareExecution
Error Message:Failed to prepare the query execution for the data set: UnitOnOffDuty
Cannot set the string value (33-34) to parameter 5.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: Cannot set preparedStatement parameter string value.
SQL error #1:Invalid parameter index 5.
java.sql.SQLException: Invalid parameter index 5.
Any ideas? I have made sure that all the datatypes are in sync and I have put default values on all of the report parameters. The 33-34 is the default value of unitname report parameter.
Any help would be greatly appreciated. I will attach the stored procedure and the rptdesign file.
