Help to fix error while opeing BIRT chart in Weblogic 10.3
Johndr
I am getting the following error while opening BIRT charts in Weblogic server 10.3. Please help me to fix it.
java.lang.IllegalAccessError: tried to access class org.mozilla.javascript.DefaultErrorReporter from class org.mozilla.javascript.CompilerEnvirons
at org.mozilla.javascript.CompilerEnvirons.<init>(CompilerEnvirons.java:48)
at org.eclipse.birt.core.data.ExpressionParserUtility.parse(ExpressionParserUtility.java:182)
at org.eclipse.birt.core.data.ExpressionParserUtility.compileColumnExpression(ExpressionParserUtility.java:77)
at org.eclipse.birt.core.data.ExpressionUtil.extractColumnExpressions(ExpressionUtil.java:282)
at org.eclipse.birt.report.model.parser.ListPropertyState.handleBinding(ListPropertyState.java:392)
at org.eclipse.birt.report.model.parser.ListPropertyState.end(ListPropertyState.java:321)
at org.eclipse.birt.report.model.util.XMLParserHandler.endElement(XMLParserHandler.java:176)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(AbstractSAXParser.java:601)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(XMLDocumentFragmentScannerImpl.java:1774)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2930)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:648)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:510)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:807)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:737)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:107)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522)
at weblogic.xml.jaxp.WebLogicXMLReader.parse(WebLogicXMLReader.java:133)
at weblogic.xml.jaxp.RegistryXMLReader.parse(RegistryXMLReader.java:173)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
at org.eclipse.birt.report.model.parser.ModuleReader.readModule(ModuleReader.java:97)
at org.eclipse.birt.report.model.parser.DesignReader.read(DesignReader.java:88)
at org.eclipse.birt.report.model.core.DesignSessionImpl.openDesign(DesignSessionImpl.java:315)
at org.eclipse.birt.report.model.api.SessionHandleImpl.openDesign(SessionHandleImpl.java:294)
at org.eclipse.birt.report.engine.parser.ReportParser.getDesignHandle(ReportParser.java:158)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.getReportDesignHandle(ReportEngineHelper.java:255)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:274)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:196)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:130)
at org.eclipse.birt.report.engine.api.impl.ReportEngine.openReportDesign(ReportEngine.java:295)
Thanks and Regards,
John
mwilliams
Is that the entire error? Are you just creating a chart with the CEAPI? Or what? Can you explain more? Thanks!
