Hi all,<br />
I'm trying to upgrade my application to use BIRT 3.7.1 version. Currently I'm using version 2.6.0.<br />
I'm using the latest stable release 3.7.1.<br />
During my testing I'm facing an exception with a report which is using a serial number(RunningCount Aggregation). This exception comes when I uses the report with the Report Engine API, if I uses the web viewer the report is working fine.<br />
I've attached a small test case to recreate the issue. This includes the report design file and a class where I'm using there ReportEngine to generate the report.<br />
Please find the error log below:<br />
Jan 3, 2012 4:03:05 PM org.eclipse.birt.report.engine.api.impl.RunAndRenderTask doRun
SEVERE: An error happened while running the report. Cause:
java.lang.NullPointerException
at org.eclipse.birt.core.util.IOUtil.writeInt(IOUtil.java:226)
at org.eclipse.birt.core.util.IOUtil.writeObject(IOUtil.java:674)
at org.eclipse.birt.data.engine.executor.transform.SimpleGroupCalculator.next(SimpleGroupCalculator.java:233)
at org.eclipse.birt.data.engine.executor.transform.SimpleResultSet.next(SimpleResultSet.java:562)
at org.eclipse.birt.data.engine.executor.transform.ResultSetWrapper.next(ResultSetWrapper.java:81)
at org.eclipse.birt.data.engine.impl.ResultIterator.hasNextRow(ResultIterator.java:584)
at org.eclipse.birt.data.engine.impl.ResultIterator.nextRow(ResultIterator.java:525)
at org.eclipse.birt.data.engine.impl.ResultIterator.next(ResultIterator.java:475)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.next(QueryResultSet.java:191)
at org.eclipse.birt.report.engine.executor.ListingElementExecutor.hasNextChild(ListingElementExecutor.java:244)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.hasNextChild(WrappedReportItemExecutor.java:86)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:62)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layoutChildren(HTMLTableLM.java:132)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:180)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at com.eclipse.birt.test.RunningCountFieldTest.main(RunningCountFieldTest.java:52)
Exception in thread "main" org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:196)
Caused by: java.lang.NullPointerException
... 2 more
</pre>
The small program to recreate the issue can be found in <a class='bbc_url' href='
https://github.com/arunpjohny/BIRT-3.7.1-RunningCount-Error'>GitHub</a>, the same is attached below.<br />
Please help me to fix this issue.
