Report Engine Command Line Problems
cbuckler
I am attempting to script the generation of BIRT reports through the command line.<br />
I have set up my BIRT_HOME, extracted the BIRT Runtime to a directory with a short path (thus correcting a problem I encoutnered initially), and created a plugins folder under birt-runtime-3_7_1/ReportEngine/ with the directory containing the ojdbc driver I use in creating the reports (correcting another issue I encountered). <br />
In a command prompt, I navigate to the ReportEngine directory, where I have copied a .rptdesign file (for convenience) and execute 'genReport.bat -f DOC -o test.doc -F <myFile>.rptdesign'.<br />
However, it then prints a series of exceptions:<br />
C:\birt-runtime-3_7_1\ReportEngine>genReport.bat -f DOC -o test.doc -F myRpt.rptdesign
C:\birt-runtime-3_7_1\ReportEngine>ECHO off
Feb 22, 2012 9:46:50 AM org.eclipse.birt.report.engine.api.ReportRunner readConf
igurationFile
SEVERE: file: C:\birt-runtime-3_7_1\ReportEngine not exists!
Feb 22, 2012 9:46:50 AM org.eclipse.birt.report.engine.api.ReportRunner execute
SEVERE: exception in parsing the paramters
org.eclipse.birt.core.exception.BirtException: error.CannotStartupOSGIPlatform
at org.eclipse.birt.core.framework.Platform.startup(Platform.java:81)
at org.eclipse.birt.report.engine.api.ReportRunner.execute(ReportRunner.
java:142)
at org.eclipse.birt.report.engine.api.ReportRunner.main(ReportRunner.jav
a:122)
Caused by: org.eclipse.birt.core.framework.FrameworkException
at org.eclipse.birt.core.framework.osgi.OSGILauncher.startup(OSGILaunche
r.java:90)
at org.eclipse.birt.core.framework.Platform.startup(Platform.java:75)
... 2 more
Caused by: java.security.PrivilegedActionException: org.eclipse.birt.core.framew
ork.FrameworkException: Could not find the Framework - org.eclipse.osgi in path
C:\birt-runtime-3_7_1\ReportEngine\plugins
at java.security.AccessController.doPrivileged(Native Method)
r.java:75)
... 3 more
Caused by: org.eclipse.birt.core.framework.FrameworkException: Could not find th
e Framework - org.eclipse.osgi in path C:\birt-runtime-3_7_1\ReportEngine\plugin
s
at org.eclipse.birt.core.framework.osgi.OSGILauncher.doStartup(OSGILaunc
her.java:123)
at org.eclipse.birt.core.framework.osgi.OSGILauncher.access$0(OSGILaunch
er.java:94)
at org.eclipse.birt.core.framework.osgi.OSGILauncher$1.run(OSGILauncher.
java:79)
... 5 more
Feb 22, 2012 9:46:50 AM org.eclipse.birt.core.framework.osgi.OSGILauncher doShut
down
WARNING: Framework is already shutdown
</pre>
Regardless of what directory I am presently in, it always prints:<br />
"SEVERE: file: <current working directory> not exists!"<br />
Any ideas?
JasonW
Do not do this:
Just add your driver to birt-runtime-3_7_1/ReportEngine/lib and modify the genReport.bat file to include the jar in the classpath. Look for this line:
SET BIRTCLASSPATH=
Does your BIRT HOME contain the ReportEngine folder?
Jason
cbuckler
Jason-
Spot on; that worked perfectly.
Thanks!
